Nitro Dave's Plate Kit Install
Here are some pics of my plate install, 92mm plate kit, cyliderhead mounting bracket for all the solenoids, custom purge line, and the two bottle mounted were the seats used to be. I am running the FJO mini for traction control/window switch. I have yet to spray the car is getting tuned next week looking to upwards of a 200shot. Switchs are in the ash tray, i just drilled some hols in the tray for a purge and arm switch. I tried my best on the pics. Well here they are let me know what you think......
[/IMG]
[/IMG]
Cool, I will be interested in hearing how the results turn out. I am changing my system over shortly, but after conversation with Dave it appears for what I want to do I would experience a lean spike using the racetronix setup.
I have a FJO mini, it has a built in TPS, i will turn them down when i get up on the dyno thanks for the tip, as far as heaters goes, i am going to get a nano eventually. You obvisouly never been to MN in the summer time, it just as hot here as it is CA, we get humidity. If i need to get the bottle temp up i just drop it in hot bath of water if need be.
