melted plugs on 125 shot help tune hsw interface for 75-100 shot
Stock C5 injectors are 28lb'ers. We are always taking a chance when we run a new kit with out a tune, whether it's wet or dry. Be safe and get it on a wide band at the minimum. Also, you'll need to be watching your fuel supply. the LT1 with miles is known to have less than ideal fuel supply IE: pump. Another reason to have a tune, then you'll also know if your running out of pump at the high load area.
Robert
Robert
