Dyno pic's inside: what is wrong?!
Old Aug 28, 2008 | 08:28 PM
860 Performance's Avatar
Originally Posted by tim99ws6
Vinny,
It's a relatively new FMVB TH350 w/ a PTC stall w/o a Tbrake. So you think it may be the stall? That's another thought. It holds just fine on the motor from what i can tell(traps 120 in 2600da), but i guess that is a definite possibility on spray.
Thats not the stall, it really looks like plain-old slip. Call the dyno you went to and see if they can get the gear ratio from those pulls. (most dyno's can but not all) If it stays steady throughout the pull, then your trans. is fine, if it soars right when your tq drops off then there is your problem.
Old Aug 29, 2008 | 10:07 AM
ShiznityZ28's Avatar
Looks like a **** convertor to me...been there done that. get a log and and map rpm v's mph and post a screen shot.
Old Aug 29, 2008 | 10:38 AM
JL ws-6's Avatar
Race your car!
There's something going on with the car that is for sure. Other things that are potentially problems, but the more I think about it Shiz is probably right I bet the converter is junk
Old Aug 29, 2008 | 10:50 AM
Tricked-Out-Toy's Avatar
How does a convertor cause a rich condition when on the spray and doesnt lean out with smaller fuel jets?
Old Aug 29, 2008 | 11:09 AM
tim99ws6's Avatar
So i called PTC about the possibility of the converter being the issue.
He said considering where the slipping or load up seems to be taking place, and that it only seems to happen in top of third, he leans toward the 3rd gear clutch in the trans being the problem? He said if it was the converter it would be happening all the time.
I have a local guy that has been aching to have a shot at the build on my trans.
Vinny-I guess you are saying that it is the trans giving out on the 150 shot? I guess it is fully possible that the trans is crapping out on the nitrous and not on motor.
I will call the trans guy this afternoon. I guess it's time for a RMVB T-brake
Old Aug 29, 2008 | 12:10 PM
yup.
Did you ask him for the 'effective gear ratio' graph or 'rpm vs speed' graph on your last runs?
Old Aug 29, 2008 | 12:12 PM
tim99ws6's Avatar
Originally Posted by 860 Performance
yup.
Not yet, got a VM left for the dyno operator. Hopefully he will call back and be able to email it to me.
Old Aug 29, 2008 | 01:25 PM
Robert56's Avatar
Robert,
I am glad to see you jump in on this thread! Actually, I am positive we had the 150 jets(per Nitro-daves plate sheet) in the plate. I ran it on the 100 jets, and it had the same problem at the track the previous week, which is why we headed to the dyno. On the 100jets, it picked up 2 mph through the 1/4.
Actually, that pic above of the nitrous hit, we even tried backing down one jet on the fuel side to try and lean out the hit a little. So, it was actually even richer than that with the correct fuel jet in there.
I read up on others problems(like yourself) and took off the entire line, as well as the solenoid to check for any debri/kinks in the line/etc. I found nothing unfortunately. I rarely post as the one asking for help, so i guess it's my turn to get schooled! I am just completely stuck on this one.
Every one of us whom run nitrous have had similar problems, and the ensuing diagnostics process, hell I still ask questions all the time. I think Vinny may be on the right track, once it starts slipping it remains slipping and thus no more increase of the torque numbers, it just can't hold it. So, getting the info he asked for would likely pin point the issue and confirm, or tell us to look else where.
Robert
Old Aug 29, 2008 | 02:27 PM
if it only happens in 3rd very well could be the tranny. but while its out have them cut it open and check it out. whats the foot stall and or tbrake stall? where it flash to on the juice?
Old Aug 29, 2008 | 02:29 PM
as for the jetting issue. If the motor does not have load on it the fuel jets will need to be lower. more load = more fuel. and changing 1 fuel jet size will only change it .3 or so at best but if its still not loaded it will need more.
JMHO
Old Aug 29, 2008 | 05:15 PM
tim99ws6's Avatar
Robert
Will do. I will get the word from the dyno operator before pulling the trans then.
It's Footbrake only, no t-brake yet. It is only footbraking to maybe 2k-2500 before pushing the tires.
JMHO
Thanks for the info!
Old Aug 30, 2008 | 06:16 AM
  #32
98Camarod's Avatar
My car did this, however it was not as dramatic up top as yours. I replaced my converter and I haven't had a problem since.
Old Aug 30, 2008 | 08:26 AM
  #33
WE need a 2nd and 3rd gear log of rpm vs mph. this will show us if its slippin in just 3rd or not if it slips in 2 gears its the convertor. i had an ati convertor that did the same thing changed it out and it went .5 faster first time out.
Old Aug 30, 2008 | 10:10 AM
  #34
tim99ws6's Avatar
I will get a log on the car as soon as possible(I'm thinking the dyno sheet will give us the best view). I will post it up when i get it from the dyno operator.
Old Sep 2, 2008 | 11:09 AM
  #35
tim99ws6's Avatar
Steve, I am getting the graph you guys asked for right not. Unfortunately I never made a 2nd gear pull on the dyno. I can say it never had any problems with hesitation on the track in first or second. Only third is where i noticed it.
Some notes on the car at the track with this problem:
-The car picked up 5mph in the 1/8, but only 2mph in the 1/4 @ 100jets
-The car picked up 6tenths in the 1/8, but 4.5tenths in the 1/4 @ 100jets
To me, it looks about "on par" with the 1/8 mile, but is just awful in the 1/4
Old Sep 2, 2008 | 12:14 PM
  #36
Pharm0r's Avatar
wow, that's completly crazy. looks like somone let a kid loose on your dynograph with a coloring pencil.
hope you fix the problem, id like to see what it was....im learning something from this thread!
Old Sep 2, 2008 | 01:37 PM
  #37
tim99ws6's Avatar
Ok Guys,
Big update: Here are the dyno views i think you were asking for. The dyno operator also sent me all the .drf files, so if you have that software, I would be happy to forward them to you to view! I also verified timing was at 22* for these pulls. Also, the DRF files are attached to this post.
Please take a look:
File Type: zip
Old Sep 2, 2008 | 05:30 PM
  #38
98Camarod's Avatar
WTF, it looks like a 3 years old took a crayon and went to town. In the second what the hell is up with the decending curve?
Old Sep 3, 2008 | 02:51 PM
  #39
tim99ws6's Avatar
TTT,
Any of you guys have any suggestions after seeing those requested graphs?
Thanks for all the help guys!
Old Sep 3, 2008 | 04:22 PM
  #40
JL ws-6's Avatar
Race your car!
The 2nd one is a typical converter flash.. my car does that.
I dunno, seems like there's some kind of slippage going on... I'd start by draining the fluid, see what it looks like. If it's black/burnt, the problem is found tranny is shot.
