Dyno pic's inside: what is wrong?!
Old Sep 3, 2008 | 07:08 PM
  #41
mrr23's Avatar
Originally Posted by b00sted
Why do the hp/tq lines cross at 4800 instead of 5252?
scaling not the same. hp max 500 tq max 400
Old Sep 3, 2008 | 07:16 PM
  #42
98Camarod's Avatar
Originally Posted by JL ws-6
The 2nd one is a typical converter flash.. my car does that.
I dunno, seems like there's some kind of slippage going on... I'd start by draining the fluid, see what it looks like. If it's black/burnt, the problem is found tranny is shot.
Your torque curve goes down as much as that? Mine flashes up and stays relatively flat
Old Sep 4, 2008 | 06:11 AM
  #43
860 Performance's Avatar
Thats not really what I expected to see.
The first and second graph show lots of slip, but as your rpm and speed climb, the slip is reducing, like a convertor thats too loose, and never grabbing. Its not ideal, but not a show stopper.
A slipping transmission wouldn't look like that, it would flatten out, then curve back up.
After looking at all the graphs, I think your dyno didn't get a clean tach signal. I say that because your mph curves look to be clean graphs, which dosen't use the tach signal, but all your RPM graphs are broken, choppy, and flat-out messed up.
Try to post this in the dyno section, and see what they have to say.
