Anyone run Spray on a boat?
Old 09-11-2008, 12:22 PM
Z284U2TRY's Avatar
Just from reading your post you are probably well above max operating rpm. My boat is suggest max rpm 4600-4800. I run 5000 rpm max wot till I trim so much it unhooks from cavitation This is on a 14.5x23 prop 3 blade. I would suggest you try more prop on the boat if you are just looking for top end. I actually have 3 props for my boat and switch them out depending on what I am doing. 4 blades are very nice but for top end your pitch is not enough.
What is your prop width/pitch?
What lower unit are you running?
Old 09-11-2008, 12:33 PM
8 second mod
Noyzee's Avatar
i run a 22 pitch 4 blade 15 3/4 i think it was, or 15 1/4 pretty sure its 3/4
its a brand new merc prop.
so i want to trim it up to the 4800 ish area and it should pick up.
Old 09-11-2008, 12:34 PM
8 second mod
Noyzee's Avatar
oh yea, its a bravo1 X with a 1.50
Old 09-11-2008, 01:07 PM
Z284U2TRY's Avatar
That is what they say. I read a prop shoot out article a couple years ago and they said something along the lines of it being ok to tickle the limiter.
I run rivers and lakes so my boat doesn't come out of the water very often.
I think your boat has more in it just from prop change for top end. I would try some of your friends prop if they let you. I know some places have prop exchange programs to find the best one for you. iboats.com does something like this.
I found this calc. It seems to be close. Check it out. http://continuouswave.com/cgi-bin/propcalc.pl
Old 09-11-2008, 01:29 PM
8 second mod
Noyzee's Avatar
yea, my buddies 3 blade i could try, but i like the 4 blade allot, it rides better, handles better, gets on plane faster etc etc, so its almost like i need a new 4 blade?
Old 09-11-2008, 03:58 PM
ZR1 DREAMING's Avatar
So is it worth it mess with a kit on an ocean boat jumping out of the water often? I can see a river and lake craft benefiting from it. Noyzee, will your boat stay planed out to utilize N2O for the additional MPH?
I just put around on lakes and have not ran the boat in the ocean... I've thought about adding some spray to it for the occasional jet boat on the water as I have a propped 20' with a 350. I'd be interested in more info on Marine N2O experiences...
Old 09-11-2008, 07:13 PM
8 second mod
Noyzee's Avatar
on the ocean i spend some time in the air, and to loose the motor speed, i think im going to get nice manifolds and mess with some props if i can find some
Old 09-11-2008, 09:41 PM
98CamZ28's Avatar
you have a checkmate and a white camaro. your the man.
My boat. 26 Checkmate
my white z
you have good taste. lol
Heh, thanks, i'm trying to run the same time that's in your sig (8.9) with my n2o car, hopefully i'll get it there this year or early next. I'll get pics of the boat up if I find some or can snap a few
