The effect of Nitrous on engine internals?
Currently I have a Lexus SC400 1uz-fe motor that has a 150,000 miles on it, it's a quad over head cam V8 4.0 aluminum block motor and I have been running a 150 nitro shot on it regularly for the last six years. It is my daily driver... An Ls2 is going to be swapped in shortly...This 1uz-fe is one of those motors that can really handle nitrous oxide and not be destroyed by it over time... After 6 years of continued use the motor still idles perfect, uses one quart of oil between changes, and no problems to report what so ever... Everything else on the car has taken a beating, drivetrain, spindles, joints, axles, etc.
The Question - Wondering how the LS2 will handle the same 150 nitrous output over time... I race every weekend, what can I expect?
This is what my current SC400 engine and dry shot nitrous system.. I want to keep the dryshot intact in the car combined with the LS2 motor.. Any thoughts on this idea?
That's my current setup in a nut shell...
Myfast70 - You have an 87 Buick GN, NICE!!! I just actually raced a built up one a week ago and got used...They can be made to go sooo fast!!! The engine whinning noise I guess from the supercharger in the one I raced was sweet sounding..
There are many many safer ways than that to add nitrous to an LS engine. They will take the abuse. Robert56 made well over 200 track passes on his LS6 with a 200-235 shot before it went. And it went on a dyno pull.
Yeah, the dry nitrous systems are not as safe as the wet nitrous systems when going with bigger shots.. As the wet systems are implemented directly into the actual fuel line and not just the air intake..
That's good news as I plan to run just a 100 shot for starters on the LS2...
When I do drop in this LS2 I just want to hook up my dry nitrous system directly into the throttle body just like I have done to my 1uz-fe motor.. It's such a simple transittion and won't cost me a penny..
Curious, are the LS2 ECU's capable of excepting the Nitrous load? I know the Lexus ECU's have no trouble what so ever adjusting... Just needed to enrichen the fuel mix courtesy of a piggy back ECU that's it.. A few adjustments on the laptop computer and I was good for six years.. Hoping the LS2 will be simular.. If not I will wire up an independant stand alone ECU if necessary..
I'm still learning about the LS2's as the one I getting is coming out of newer Trailblazer..
That is exactly what I was hoping for, either that or a direct feed into the throttle body itself like I have now on my Lexus V8 motor.... Before the MAF would make sense for sensor reads, but being feed nitrous far away from the throttle body itself makes me wonder if the NO can get diluted just a bit or something... If that doesn't work I could always easily make my system a wet system and feed the nitrous directly into the fuel line which I should probably do anyway.. That way each injector always gets an even NO mix.. I am still trying to learn all about how the electronics work on these newer LS2 motors and the computer that runs them... Thank god for forums like this...I tell you it's alot different from the 1uz-fe import V8 that I am use too toying with during the last 10 years......
Thanks for the replies fellas..
Jetlag - Are you spraying the dry shot into an LT1 or LSx motor? Your only running a 65 shot and that's very small?...That's very minimal and safe and you are probably very smart using the dry system from what I have been reading....Even if you run a little lean with a 65 shot you probably won't do any damage.. I personally gotta have the 100-150 shot or it's not worth my time and that is a bit of concern with the dry system.. With the 100 shot or more you really feel the NO kick in and light up those rears also.... Progressive output is usually needed if you spin out of control in the early gears which can usually be the case with the bigger V8 motors that already support good N/A power....
Also, the LS2 has bigger injectors than an LS1..so it could easily handle a 125-150 shot.
Let me know if you have any questions about the interface. I can shoot you over an install manual to read through if you'd like a better understanding of its functions. Thanks.
Nick
You may wait until you get the transplant in and do some measuring to make sure you have enough room to move the throttle body forward before purchasing a plate. Unless you know someone that has already done it and you can varify room. I have a few customers that have done some conversions that were very space limitied. Mostly the RX7. We have a local guy that just put oone in the same car as you. I can find some pics for you if you need them.
NOS Plate = 1/2 thick
Nitrous Outlet plate =5/8 (little under 3/4)
HSW Plate = 1 inch
You may end up being better keeping the nozzles.
Just my two cents.
Dave
If the NOS Plate is bulky I probably will pass on it.... Like I said I was hoping to simply implement my current nitro dry system to the LS2 motor via the direct throttle body tap and screw mount like I have now... With it having to be installed pre MAF on the LS2's I will weigh in all my possible options and go from there when the swap is in it's finishing stages... I haven't got that far ahead in this swap yet and I will deal with it when the time comes... Thanks for all the suggestions fellas as they are all noted and well recieved...
My main issue now is the transmission transplant, as in which one to go with.. The lexus will not accomidate a transaxle swap which I wanted to originally try with the LS2 and tranny straight out of newer Vette... I am now measuring and trying to fit TH400 and others... I need a mid tranny mount for sure... Some welding and fab work will be needed but is very doable... My lexus rearend (independant axles and torque sensing LSD will stay intact.. Basically I will be shortening, balancing and welding a GM end housing on one side of the driveshaft and the Toyota/Lexus on the other and that will get the ball rolling for the tranny swap... The differential gearing ratios should work out just fine....
Just sharing my deal with you guys if anyone is interested... Swaps are challenging to say the least but can be very rewarding and rare when the finished product is what you expected... I am expecting 400whp out of the LS2 (N/A power) after mods, combined with a strong performance automatic transmission, then to finally implement the Nitrous dry or wet system to add another 100whp to the package....That is what I am shooting for in the end...
Thanks again..
We got a Lexus hater.. I knew it was coming sooner or later.. It's all good though.. Race you for pinks? Then you can blow it up yourself if you win...
