Detonation Sucks
Old Sep 13, 2008 | 10:04 AM
  #41
ATVracr's Avatar
NGK 10 plug with 350 shot running Q16 fuel.
I was told this was still a little rich and has 1* to much timing.
Old Sep 13, 2008 | 11:33 AM
  #42
gvzo6's Avatar
Originally Posted by JL ws-6
The autolite AR 3910 is what I would use. It is a nascar style plug with a cut back ground srap that is a little stronger, so they will take 2 runs to really show the heat, I would start off with the #8 ngk plug because it will show heat after one run alot better, but once you know your tuneup is good then go to the autolite plug, they don't seem to foul as bad, the tips aren't protruded, that type of thing.
I don't know what ya have for compression, but I look at it like this:
11 to 1 or over n/a #6
11 to 1 with 100 shot #7
11 to 1 with 200 shot #8
11 to 1 with 300+ #9
once you get to 13 to 1, I'd go to a #7 n/a, and for 100 shot a #8, 200 a #9, etc.etc.
Personally, I'm on a 13.5 to 1 compression motor, and am running a 150 shot, I run a #9 plug. I'm gonna start playing with the jetting a little, therefore I got some #10 plugs for a little added safety net.
Each heat range you go down lowers the combustion chamber temps by about 100 degrees (rough rule of thumb) so that may be enough to save you from some damage. Noone ever hurt anything from running too cold a plug, ya just foul them out easier.
I gap everything at 35, gap them too tight and the car gets a little harder to start and whatnot, plus this is a way to be consistant to see what just the plug change does.
I dunno about running different plugs in different heads, I'm running ET heads and am running the AR 3933 normally, and have some AR 3932's to go to for my next outing/testing session.
from what i have noticed the plug chart for the ngk-8 r5672a 7173 is a projected tip plug ,the plug you need is a ngk-8 b8efs 1049 it has a non projected tip but it is also a non resistor we hit a couple of cars with 300 shots with c16 in a stand alone and never had any problems
Old Sep 13, 2008 | 12:22 PM
  #43
koolrayz's Avatar
Originally Posted by algws6
can some post pics of projected and nonproject plugs. btw, this is a great thread.
Plug on the left is a projected TR8 Plug on the right is a non projected TR7
What is the general feeling on a plug being colder but projected?
It would be nice to change the stickie to include a breakdown of plugs by temp and all the part numbers for projected and non projected. It appears some part numbers are missing? This is a good thread. To think I almost didnt start it. Thanks to all that participated!
Old Sep 13, 2008 | 12:54 PM
  #44
JL ws-6's Avatar
Race your car!
I'd try to stock with non projected tips, being that the electrode is much closer to the head there's alot less of a chance of the glow plug effect, regardless of te plug's temp rating.
Autolite my friends.... non projected and the ground strap is cut back some already on top of it. They don't melt, and are available in the cold heat ranges we need to be running.
Old Sep 13, 2008 | 01:01 PM
  #45
algws6's Avatar
are they the same part numbers that are in the stickies? if not can you post up some part numbers with the heat ranges?
Old Sep 13, 2008 | 01:23 PM
  #46
JL ws-6's Avatar
Race your car!
Autolite AR 3934 #8 heat range
Autolite AR 3933 #9 heat range
Autolite AR3932 #10 heat range.
Guys with street cars will complain that the #8 idles rough and starts a little harder then they're used to with the hotter plugs, but with these the chances of a plug turning inot a torch are alot less.
I run the 3933 with a 150 shot, but have some 3932's for the next outing Please keep in mind I"m running alot more compression then the average guy on here with 13.5 to 1.
Old Sep 13, 2008 | 01:57 PM
  #47
waterbug1999's Avatar
Well, I just bought a set of these for the 175 shot. I hope its good to go!
MFG Recommendations: approx 11:1 compression
Heat Range: 8
Gap: Consult ignition mfg.
Plug: NGK R5672A-8 (stock number 7173)
I also bought a set of these as well incase the car does not like the #8's
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346)
But, from the info above, it says one has a reach of .75 (3/4") and the other is .70. Does this make any difference?
Old Sep 13, 2008 | 02:42 PM
  #48
ATVracr's Avatar
Autolites do melt, and when they do your motor is FUKED!!!
If you melt an NGK there is a 50/50 shot you might be OK.
NGK's are much easier to read also......I run NGK's FWIW.
Old Sep 13, 2008 | 03:43 PM
  #49
koolrayz's Avatar
Perfect example. My car is running and appears no worse for the wear. leaned on it this morning and its all good. The fuel pump was the problem
Old Sep 13, 2008 | 03:48 PM
  #50
JL ws-6's Avatar
Race your car!
No I agree if you melt down the autolite's your motor is definately fubar. I generally reccommend people start with the NGK because you can get a good read on the plug after one run, the autolite's it's harder to do.
But, once you have your tuneup set the autolite plug IMO is a better way to go.
I just got a bunch of #10 plugs today, 4 sets of autolites and 2 sets of NGK's, NGK will get the first couple runs.
Old Sep 13, 2008 | 05:47 PM
  #51
Loudmouth LS1's Avatar
I run the r5671A-8 or -9, depending on the shot, non projected tip, dunno about the resistor thing, but they seem to work well.
Old Sep 13, 2008 | 07:38 PM
  #52
gvzo6's Avatar
is that a tappered seat plug?
Old Sep 13, 2008 | 07:41 PM
  #53
ATVracr's Avatar
No, gasket style
Old Sep 13, 2008 | 08:02 PM
  #54
gvzo6's Avatar
No, gasket style
do the plug holes on the heads need to be retapped to use that plug?
Old Sep 13, 2008 | 08:10 PM
  #55
ATVracr's Avatar
I have ET heads and you can use either style with them.
you can only use tapered seat plugs with Stock heads
Old Sep 13, 2008 | 08:15 PM
  #56
Really? I've been running the gasket ones, one of my spark plug holes has a helicoil in it, so my machine shop guy told me I had to run a gasket style in there and he said it was ok to run them in the others so I didn't have to buy seperate plugs, is there any problem with running them in the stock casting heads?
Old Sep 13, 2008 | 08:21 PM
  #57
ATVracr's Avatar
Hell maybe I'm wrong then.....
its been a few years since I had stock heads .... lol
Old Sep 13, 2008 | 08:43 PM
  #58
gvzo6's Avatar
this is a ? that needs to be answered ,it will solve a lot of the spark plug heat range issues ,can the tappered seat and gasket seat plugs be used in the same heads?
Old Sep 13, 2008 | 11:18 PM
  #59
ShiznityZ28's Avatar
I used both in my afr's
Old Sep 15, 2008 | 05:06 PM
  #60
david vericker's Avatar
Where can I buy the Autolite AR94 spark plugs - heat range #7?
