Nano Street/Strip Systems!!
Old Sep 24, 2008 | 10:58 PM
BOTTLEFEDLS1Z's Avatar
Originally Posted by waterbug1999
What do you mean?
Not having the pressure drop thru the run like a heater would. The consistency of the bottle pressure vs losing pressure, i think...
Old Sep 24, 2008 | 11:46 PM
waterbug1999's Avatar
I was thinking he meant in a wheelie or somehting.. lol
The pressure was creeping up while in the stagin lanes... But, thats why they say to keep it cool. But, as soon as I hit the gas the pressure came down to ~950 psi and stayed there.
Old Sep 25, 2008 | 01:00 AM
BIGB4015's Avatar
will thiss work with my hsw bottle? Is the valve needed?
Old Sep 25, 2008 | 09:24 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I "think" it will....you might want to verify with HSW to make sure tho.
You need to know if their pressure port accesses the siphon tube or the pressure above the liquid.
The base of the valve should have a small hole that lines up with the pressure port if it compatible.
this is a NX 45* valve...it has 2 pressure ports...as you can see there is only one port on the base, so only one of the side ports can be used with the NANO
