microedge users, which o2 wire did you use?
Which stock O2 sensor wire did you use for the input signal to the microedge unit?
I haven't had a chance to dig and find it yet, and was hoping to get some quick help here while I was still hooking up this baby!
Should be spraying tommorow!
Thanks
Thanks
Check out the instructions, there is a little paragraph on how to test each wire to ensure you get the correct one. On the F-bodies, the purple wire is the one you want to tap into. Good luck and happy spraying!
Nick
Nick
