extreme bottle pressure!
Ya almost have to have a hot box to get them up to temp, once they're up I think the electric heater will hold one up no problem... but it's getting it up there that's the issue.
I'm gonna actually sell my 10 lb bottles probably over the winter, and pick up 6 or 8 15 lb'ers, so I have enough nitrous for a couple track trips without the refilling headache. I'll make sure all the bottles are the same and have guages on them, and I'm gonna look into building a hot water bath once I have the enclosed trailer so I can easily just stick them in some nice hot water for a few min and get them hot quick.
It should work... At least I hope LOL.
http://www.nitrousoutlet.com/catalog...roduct_id=2695
We use this on our test bench. Works awesome..
Dave
And yes, I'm gonna look into my own refill station, 'm gonna weigh the + and the - of it, maybe get 3 or 4 15 lb'ers, and put the $ towards a refill station rather then more bottles... I just have to look into the gas company and see what I can get it for. The biggest concern at this point, is getting mother bottles that aren't all the way full, you pay for 56 lbs of nitrous and if the mother bottle only comes with 40 or 45 lbs in it, that's a problem.... so I have to look into it with the gas company, see what kind of an account I can get set up, see if there's a way to get the botles delivered, and if they will allow weight verification @ delivery of them to make sure they're full, that type of thing.
Have to see.
Dave, that's a very nice piece, I have seen the air powered hot box, that setup you have thre is what I was thinking about trying to build, but for the $ I'll just buy once once I have the enclosed trailer, by far easier then building one.
I can get 2 runs with the 150 shot off a 10 lb'er and they're both good, the 3rd I haven't tried, but I suspect it will be weak.
15 lb'ers, I think at a 200 hit I should be able to get 3 runs, the 10 lb'er's I bet the 2nd run gets weak.
I don't have a problem heating them now, as you said in the summer it's fine, but a night race (like pinks was) and in the fall it can be a problem. This Friday I have a rental day I'm going to, it's supposed to be a high of 63. That means it's gonna be about 40 when I get there, so it's a little more of a PITA. All the bottles will be in the truck for the ride up, one on the floor with the heater blowing on it on the ride there (takes about an hour and 45 min), at least one will be warm when we get there.
I'm gonna rig up a mount in place of the passenger's seat to put 2 bottles in the car probably while I'm on my break next year, and I'm gonna get the 2 strongest electric heaters I can, put them on, and I'll run a good high current connector on them, and on the pit veichle I'll put a big *** deep cycle battery I can hook them to to keep it hot. Should work, and not kill the battery in the car, as long as they go in hot (which that water bath thing that Dave has should work no problem I'd think)
Maybe a 16 volt battery, the added voltage would help, maybe 2 of them. I dunno yet, have to see how a single big 12 volt works first I think.
The draw back is they are never as charged and heated like the 10lb bottle... You get such a better pop out of the 10lbs... I regret selling my 2 10 bottles on Ebay.... Now, I only got a 15 pounder and it's getting old fast....
Nitro Dave - You guys have all the nitro goodies...That heater box looks interesting and it's too bad it costs $615 and more then my intire Nitrous system all together... I can't invision how that heater box works? It looks like you actual shoot the nitrios thru the box or something, or does it heat the bottle up?..Just not sure?
The hot box works just like a HOT TUB.
Fill the box with water and set the controller to what temperature you want it. It will bring the bottle pressure to the set point in a matter of a few minutes..
If there is a big enough interest in these from the racers I will put together a group purchase... Get me some feed back and lets see if we can make it worth each others time and expense.
Dave
(torching a bottle up, is a big no no at every track I know of)
