Fogger nozzle limits???
Old Sep 6, 2003 | 05:43 PM
lrmneil's Avatar
Default Fogger nozzle limits???
Dynoed the car today with and without the spray first baseline pull was 335rwhp with 336tq only mods are a TR220 and a lid. Then with the 150 pills in it dynoed 440/503, so I changed the jets to the 175 and it pulled 434/548 WTF is going on. Everything checked out perfect A/F was 12.1 bottle pressure was at 1050. Seems that there is some kind of restriction in the system? the system is a basic nos wet kit with super power shot solenoids. Give me some ideas what to check for. I was thinking that the nozzle it at its limits?? Or maybe the fact that I still have the stock exhaust system with cats?
Old Sep 6, 2003 | 06:25 PM
BMN's Avatar
BMN
Default Re: Fogger nozzle limits???
Your fuel pump can only supply so much. You probly max'd it out with the 175 jets. Lots of guys that us NX go from the 100 or 125 to the 150 and find that they loose power and start to run lean. Others say its the intake. Was your A/F in the 11's then dipped into 12 up top? 12.1 is nice though.
Old Sep 6, 2003 | 06:40 PM
lrmneil's Avatar
No it was in the high 10's then I leaned it out with a diffrent jet size until 12.1, seems if it were running out of fuel it should be lean?
Old Sep 6, 2003 | 06:51 PM
squeeze's Avatar
The NOS fogger limit is 150 shot.WHat size jets are you running for fuel and N20?On an LS1 car the jetting should be a 61(N20) and a 32(fuel).
Old Sep 6, 2003 | 06:57 PM
lrmneil's Avatar
First on the 150 it was 63/34 then on the 175 70/38 and lean it out to 32 so it was a good A/F. The torque went up a bit but hp dropped??
Old Sep 6, 2003 | 07:05 PM
lrmneil's Avatar
I am starting to think the stock exhaust is the big concern, the car traps 118mph at the track also.
Old Sep 6, 2003 | 07:07 PM
Z06PSI's Avatar
Also main line can limit.... I run the TNT dual fogger #52 jets for the 150 and I would think that the main supply line is a limiting factor after awhile...I knew a guy that ran open single fogger dry kit (no jets) and ran some good numbers.....on a completely stock ws6....
Old Sep 6, 2003 | 08:42 PM
lrmneil's Avatar
I really don't think that is an issue (main feed line)
Old Sep 7, 2003 | 07:45 AM
383LQ4SS's Avatar
Im running a 300 shot through my main -4 feed line. So thats not an issue at that level.
If you want more power Id look nto upgrading the solinoids..both of them. But of course be sure you wioll have the fuel to handle it. Also I would try atleast a cutout to free up some exhaust flow.
Old Sep 7, 2003 | 11:05 AM
lrmneil's Avatar
Thanks for the replies I think the next step I will try is a set of Long tubes and exhaust.
Old Sep 9, 2003 | 02:18 PM
GreekZ's Avatar
Upgrade the solenoids, the powershot can only
handle 125shot. The NOS ProShot can support
a 300shot.
Old Sep 9, 2003 | 06:52 PM
Aidan's Avatar
I have cheater solenoids on my NOS kit and i can only get 125 rwhp out of the nos fogger setup no matter what jets i throw in it.
Purchase a Nitrous Express Fogger and stick it in, You can then go up to 175 horsepower on your nitrous kit and just keep the rest of your nos kit.
Old Sep 9, 2003 | 08:30 PM
redsscamaroboy's Avatar
I think the NOS fogger nozzle is limited in how much it can flow. I removed my NOS fogger nozzle and took it apart just to see what it looks like and i think i found my restriction in my system. The jets i run are 150 to the wheels 63/32. I run 11.60@118 and can not get any more mph . I replaced the noids with much bigger,then added long tube headers and y pipe but still no mph at the track. The 63 jet is bigger than the opening inside the fogger nozzle.(look for yourself). I am switching to an NX shark nozzle and retesting at the track for mph increase.
I ran back to back runs with the 100 shot in and then the 150 shot jets and no difference in mph with the o2 readings in the 940 range, not lean.
Hope this helps some,Good luck.
By the way , nice numbers!!
Dave
Old Sep 9, 2003 | 09:01 PM
lrmneil's Avatar
I took my nozzle apart and you are right, very much a restriction in the system so I will need to get something different there also,
Old Sep 9, 2003 | 09:06 PM
B18B1LS1's Avatar
I really doubt it's in the nozzle, mine flows 150 rwhp with no problems. I would look elsewhere.
Jeffrey
Old Sep 9, 2003 | 09:18 PM
Jeff i am glad the NOS fogger nozzle works for you,great mph on your car,but it is visibly smaller inside than my 63 jet is. Maybe we have different nozzles.
Dave
Old Sep 10, 2003 | 07:04 PM
B18B1LS1's Avatar
Drill that sucker out
