Where to set window switch?
Old Sep 25, 2008 | 11:06 PM
OLDSCHOOL85's Avatar
Default Where to set window switch?
I have a 2000 Camaro with Patriot Ls6 Heads,.581 lift(224/224) cam,vig 3600 stall that flashes around 4000K,3.27 rearend. Harris plate system with 125 shot.Where to set the rpms for the window switch? Any suggestions?
Old Sep 26, 2008 | 02:22 AM
RedsrtAk's Avatar
stay above 3k and you'll be ok. Other then that, its kind of at up to you.
I'll adjust mine from anywhere from 3k - 3.8k depending on the track.
Old Sep 26, 2008 | 02:39 AM
krazy4's Avatar
I would do around 3500 rpm and about 100-200 rpm before the limiter.
Old Sep 26, 2008 | 09:57 AM
Midnight02's Avatar
3000 rpm is widely regarded to be the minimum and most people take it to 100 - 200 rpm off your shift rpm.
Personally, I was more conservative with my progressive controller setup -- 3300 rpm = 75rwhp shot that ramps up in a straight line to a 100rwhp shot by 4000 rpm and it shuts down at 6300 rpm. My shift light hits at 6400 and I'm usually banging it right around there.
Old Sep 26, 2008 | 01:06 PM
purdueranger's Avatar
3500-6800RPM in my SBE car.
