Calling it a season, more damage then i thought
8 second mod
thanks for the info. i had to make a shim plate for my harland sharps as well to me thats no big deal.
vinny, no way, the vett runs 12.0 not 11.50 and i cant get tires for 3 months. the 315's are back ordered
8 second mod
as of now im thinking up the cage to a 7.50 cert, re ring/bearing the motor, try to sell my heads and pick up a set of 6 bolts from TEA, and maybe add a 2nd stage DP set up. id really like to get a 400 back in the car as well but i have to sell my glide first.
other then that nothing crazy i think with a 2nd stage and a fresh motor and a 400 i think i could tune it in pretty easy to run the 8.50 class at my local track and maybe hit it hard a few times to see what she will do
FI your upping the shot the glide would work out nice.... Why the switch?
#33
8 second mod
i want the 400 so i can run the local 9.50 class on motor and with the glide and 4:30's it just wont do it with my nitrous converter. i know it would with a 400 and the right gear. if i dont sell it, i will stick with what i have tho and just spray the ***** off it. lol
#35
Keep the glide! If you are real worried about running an all motor class get a neal chance bolt together and switch before you head up to the track if you want to go all motor. Sure it's a pain in the ***, but I think the glide and spraying the **** out of it would be the way to go!
