NOS plate kit wit a T56?
Old Sep 29, 2008 | 10:43 PM
juicedls1's Avatar
Default NOS plate kit wit a T56?
I was wondering if there would b issues wit fuel puddling wit a plate kit while changing gears in a t56? I had a nozzle kit b4 and it worked great, then i sold it. Now i got a plate kit and i'm worried bout having a backfire! It will n wired up wit a full throttle switch but no window switch! THANKS n advance!
O and this is on a 01 ta.
Old Sep 30, 2008 | 05:28 PM
juicedls1's Avatar
Anyone???
Old Sep 30, 2008 | 05:35 PM
rpmauto's Avatar
get a window switch, i bent all my intake valves when i missed a gear, and yes i never missed a gear before and have not since, but it only takes just once.
Old Sep 30, 2008 | 10:01 PM
juicedls1's Avatar
THe way i see a window switch is diff than a full trottle switch is it activates the juice at a desired RPM, both shut it off when ur not full throttle! U can bend valves and pushrods from overrevving. I c if i can find a cheap used window switch just to be on the safe side!
Old Sep 30, 2008 | 11:14 PM
1BDWS6's Avatar
Another cheaper alternative would be to wire your arming switch into the clutch safety switch. More than likely if you miss a gear you are not going to take your foot off the clutch all the way. While it is still not fail proof, it's just a little extra security.
Old Oct 1, 2008 | 02:13 PM
Midnight02's Avatar
Given that you can pick up a window switch pretty cheap, the simple fix would be to simply buy one.
I went a step further and spent $150 on a progressive controller that has a built in WOT switch and window switch and it works like a dream. With the progressive controller it truly is a simple two step setup: Step One: press the button to arm the system. Step Two: Slam it to the floor. It makes life so much easier in a 6-speed.
Old Oct 1, 2008 | 02:51 PM
1BDWS6's Avatar
X2, I love my progressive controller.
Old Oct 1, 2008 | 05:26 PM
juicedls1's Avatar
Where can i find the best deal for a progressive controller? Thats sounds better than a window switch!
