NOS fogger nossle spray direction
do the fogger nossles really spray at a 90 degree angle or are they just designed to be mounted 90 degrees from the direction of the airflow? someone told me that they actually spray at a 45-60 degree angle
Let me give a little more background on the question. I have a fogger nossle mounted on the passenger side of the hose between my maf sensor and my throttlebody. because of the IAC on the left side of the throttlebody, the actually throttlebody opening is a little to the right. what i'm worried is that if the nossle is spraying at a 90 degree angle that it is spraying directly at the side of the throttlebody. I'll see if i can find a picture or take one when i get home...
on the left side of the t/b where my nossle is pointing there is a good amount of material before it actually gets to the opening. what i'm worried about is the nossle spraying against that instead of into the intake tract. especially since the rubber connector is kinda pliable and the way the hoses are they tend to angle the nossle more so that it's pointing towards the side of the intake instead of the center. should i have concerned about that?
