NEW! Xtant X604 & X1001 car audio amps MINT! pre MTX
SOLD
Try a PAIR of New Old Stock XTANT amplifier from before the MTX ownership days. I searched for 18 months to find a New Uninstalled version of both the Xtant X604 4 channel 600watt amplifier and the Xtant X1001 1,000 watt mono amplifier. I'm selling these as a pair because they are physically the same size and will provide at least 1,600 watts of TRUE audiophile power for any car audio system.
They still have the factory protective plastic covering the polished stainless steel covers!
I DO NOT want to split these up and will not accept offers to do so. If you would like to buy them as a pair and sell the other, there isn't much I can do about it. If I do not get my asking price I will keep them for future use. I have several other pictures available upon request, just provide me with an e-mail adress and I'll be happy to forward then on to anyone who ask'
New these babies cost me well of $2k. They are available now for $1,000.
For more information and pictures about these VERY amps check out this link...
I 'm having with picture size but here are specs on these amps...
X604 Features
Fully Regulated PWM Power Supply
Complimentary MOSFET Design
Defeatable Balanced Input
Adjustable Input Sensitivity
24dB/Oct Low Pass, High Pass, Bandpass Crossover
RCA Outputs with 24dB/Oct Crossover
Left & Right Independent Gains
Adjustable Noise Gate
Passive Rear Channels
X604 Specifications
Number of Channels: 4 ( 6 with supplied passive output chip installed)
Watts per Channel @ 4Ω: 4 x 75
Watts per Channel @ 2Ω: 4 x 150
Module Port(s): 2– Accessory
On-Board Crossover: 12 or 24 dB per Octave “Butterworth”
Frequency Response: 20 Hz to 20,000 Hz +/- 3dB
Signal to Noise Ratio: > 100 dB
Distortion (THD): < 0.3%
Operational Voltage: 11 to 15 Volts
Size (L x W x H): 23.63” x 10.28” x 2.16”
X1001 Features
· Regulated Transitional Class D Technology
· Fully Regulated PWM Power Supply
· Complimentary MOSFET Design
· Defeatable Balanced Input
· Adjustable Input Sensitivity
· 24dB per octave variable Low Pass Crossover
· RCA Outputs with 24dB/Oct Crossover
· Phase Inversion
· 1/0 gauge Power and Ground Connectors
· Dual Speed Fan Circuit
· Forced Convection Cooling
· Protection Circuitry
· Balanced / Floating Input
· Modular Expansion Port
· Status LEDs
· Made in the USA
X1001 Specifications
Number of Channels: 1
Watts per Channel @ 4Ω: 1 x 500
Watts per Channel @ 2Ω: 1 x 1000
Watts per Channel @ 1Ω: 1 x 1000
Frequency Response: 5 Hz to 500 Hz +/- 3dB
Signal to Noise Ratio: > 90 dB
Distortion (THD): < 2%
Damping Factor: > 200 @ 100 Hz with 4Ω Load
Input Sensitivity: 100 mV to 8.5 V RMS Unbalanced / 100 mV to 17 V RMS Balanced
Input to Line Output Gain: 0 dB +/– 20 dB, Selectable in 10 dB Steps
Line Outputs: Yes, High Pass or Bypass Mode
Power Supply: Fully Regulated, Pulse Width Modulated
Fusing: Requires 120 amp
X604 Features
X604 Specifications
X1001 Features
· Phase Inversion
· Status LEDs
· Made in the USA
