Notices
Non-Automotive Classifieds Sell almost anything here, with the exception of firearms and ammo
Tools
Old Mar 8, 2009 | 12:38 PM
dmracing's Avatar
Default Tools
channellock 447 diagonal cutters
Brand new
Shipped to you 15.00
Product Description
7-3/4", 195MM, Diagonal Cutting Pliers With Curved Jaw, Perfectly Mated Cutter, Laser Heat Treated Cutting Edges, Electronic Coating To Prevent Rusting, High Carbon Forged Steel, Channellock Blue Comfort Grips.
channellock 326 long nose pliers
new
14.00 shipped to you
Detailed Description
Features and Benefits:
Cross hatching on jaws
Perfectly matted cutter, heat treated to hold its edge
Polished high carbon drop forged steel
CHANNELLOCK BLUE comfort grips
Length: 6"-150mm with side cutter
6" long nose side cutter pliers. Channellock® uses high carbon C1080 steel for superior performance on the job, and an electronic coating for ultimate rust prevention. Most of the manufactures use two sharp edges which can eventually become misaligned, losing there cutting effectiveness over time. Channellock's knife and anvil ensure proper cutting edge alignment resulting in a clean cut every time! Also this is to ensure perfect mating and superior cutting edge life. The laser heat-treated cutting edges last 3 times longer! Not only made for durability but for comfort as well, with the blue grip handles
Proto professional Ratchets
New 1/2 and 3/8 ratchets
30.00 shipped to you
3 piece Crescent wrench set
6 inch
8 inch and 10 inch wrenches
new 30.00 shipped to you
CP 828 Air ratchet with % universal impact sockets
45.00 shipped to you.
Ingersoll Rand 2135 TIMAX Impact
The 2135Ti set the standard for performance with the best power to weight ratio on the market in its class. The new 2135TiMAX raises the bar with 780 ft. lbs still at only 3.95 lbs. The new design includes enhanced controls for even greater comfort and convenience. We're so confident with the durability of this tool that we are backing it up with a 2 year warranty at no additional cost.
Product Description
Specifications: Max Torque (Reverse) 780 Ft/Lb (1054 Nm) NBT 1,100 Ft/Lb (1486 Nm) Forward Torque Range 50-550 Ft/Lb (68-746 Nm) Blows per Minute 1,250 Ingersoll-Rand 2135TiMAX 1/2" Drive Titanium Duty Air ImpactoolTM
110.00 shipped to you
I will ship everything to you in this ad for 200.00 shipped to you this is all like new condition
PM ME
Old Mar 8, 2009 | 11:44 PM
PipesTA's Avatar
Got any pics of the IR impact gun? Anything wrong with it? Interested...
