Side down draft paint booth
Up for sale is an Auto Body Toolmart side down draft paint booth, model #8552 that was bought new in April of 2002. It was used for painting parts of two cars before the business went under. It has been used as boat storage since then.
Specs from the maufacturer:
External dimensions: 26'4" long x 16'4" wide x 9'2" high
Interior dimensions: 26' x 14' x 9'
Door clearance: 8'6" wide x 8'10.5" high
All panels are air tight, 18 gauge galvanized prime steel fastened with 5/16" bolts
All panels have 2" flanges with pre-punched holes for easy nut and bolt assembly.
Gabled roof designb gives better air flow, lighting and overall strength
Ten 48" four-tube flourescent light fixtures with clear, tempered glass and seals..
Twin 24" diameter tubeaxial fans with aluminum spark-proof blades
Fan motors are 3 phase 240/480 volt, 16,370 total c.f.m. @ 1/2" static pressure
Booth uses twenty 20" x 20" 2.5" economical arrestor filters with internal wire support
Equiped with 2 Dwyer manometer draft gauges for exhaust filter monitoring
Brixon safety latches on all doors
Meets NFPA 33 standards for fire resisyance as well as OSHA and BOCA guidelines
Comes with two 9' chiminey kits with ARV
All quality components made in the USA
The booth is currently disassembled and is palletized unless buyer wants otherwise. Located in Indianapolis, IN. Email or PM for pics.
$6500 or trade for something interesting + cash
