Coleman Gas Generator
3750
Used once
375 O.B.O. , works perfectly
call or text 1 772 985 5270
located in vero beach florida, would perfer local pick-up to make everything easier
****Below is a copy of what it looks like with all info about it ! Thanks guys****
http://www.amazon.com/Coleman-148-37.../dp/B000KCXF9G
This 3750W portable generator comes standard with a wheel and handle kit. Equipped with a 6 HP OHV gas engine, 3 quart gas tank provides up to 2hrs run time @ 50% load and operates at 3000W with a max of 3750W. Premium Plus Series generators are manufactured with OHV engines to provide improved fuel efficiency, longer life, easier maintenance, and less noise. These generators are great for backup power at home or on the job site. Large extended run fuel tank will give you hours of power. Features 6 HP Briggs & Stratton OHV gas engine 3000 Running watts 3750 Maximum watts Overhead valve (OHV) engine provides improved fuel efficiency, longer life, easier maintenance, and less noise 3 quart gas tank provides up to 2 hours run time at 50% load Two 120 volt outlets with circuit breaker protection Unique design makes unit compact and easy to transport Extra large 14" wheels maneuver easily over job site terrain Reversible handle with extension cord wrap adjusts to your personal preference More Information Model NO: PM0543000.01 Max Watts: 3750 Run Watts: 3000 Engine HP: 6 Gas Tank Size: 3 quart Run Time: 2hours @ 50% load Warranty: 2 Year Limited Dimensions: 26.5" x 25.63" x 24.25" Weight: 116 lbs.
Used once
