High Voltage and Vacuum Equipment; CPS, Behlke, Ultravolt, Varian, Nor-Cal, + More N
All of the links are details for the items for sale. The prices listed are retail values of the items. 38/63 items have been researched with a retail value calculated of $39964.87. Items are sold as is with no warranty or guarantee of condition.
I am asking $5,000 Shipped in the Continental USA for these items. If you are not located in the Continental USA please contact me about shipping arrangements.
Photos Located at:
http://s395.photobucket.com/albums/p...cpZZ3QQtppZZ20
Please note: “Photos are in reverse order of what is listed”
Contact information:
1. Cooper Crouse – Hinds pin & sleeve receptacle back box – Model # AJ57, SKU 678082 - $ = 237.84 http://www.drillspot.com/products/67...tacle_back_box
2. MDC Vacuum Products # = IV-150-P-OPT-2, $ = 5x $350 http://www.4Semi.com/iinfo.cfm?ItemNo=217
3. 24VDC Turbo Control Assembly – Source turbo pump, 24VDC power entry, CID turbo pump, reflector turbo pump. $ = $400 http://www.ebay.com/itm/Turbo-Contro...5#ht_500wt_677
4. Edwards active thermocouple gauge # = D35108000 ATC-E Electronics. $ = $220.15 http://www.edwardsvacuum.com/Product...8000/View.aspx
5. Nor-Cal Products NW to CF ANC-NW-25-275 NW-25 to 2.75 OD CF conical adapter nipple. $ = $85 http://www.n-c.com/CatalogSet.aspx?p...o_CF&i=01FTG03
6. Solidsealing SHV 10KV KT10606 “Grounded shield exposed 10kv 304ss conductor weld with plug.” $ = $169.00 http://www.solidsealing.com/parts/listing.cfm?pcid=3
7. Unidentified CF Fittings
8. Various Fasteners
9. 2x MDC SS Rings
10. CPS High Voltage – Power supply 2591P “Precision electron and ion beam high voltage power supply.” $ = $1162.00 http://www.cpshv.com/products/2591pdata.htm
11. CPS High Voltage – Power supply 2591 “Ion beam power supply.” $ = $1188.00 http://www.cpshv.com/products/2591data.htm
12. Behlke – Fast high voltage push – pull switch HTS31-03-GSM
13. 2x Behlke – High voltage transition switch HTS50
14. Various Inline Resistors
15. Varian TV-301 Turbo Molecular Vacuum Pumps – Model 9698918. $ = 2x $6995.00 http://www.ajvs.com/varian-v301-navi...-9698918-r-233
16. Varian TV-250 Turbo Molecular Vacuum Pump – Model 96990075036 $ = $4450.00 http://www.ajvs.com/varian-v250-turb...-9699007-r-202
17. Undetermined
18. 3x Cords
19. Huntington Mechanical Laboratories Model FTR-150-SF. $ = $ 235.00 http://www.huntvac.com/products.php?t=series&id=673
20. Metra Inc. Model 1000-026 / Serial 9375
21. Nor-Cal Products 3T-150 “Flange OD 2.75”, Tube OD 1.50”, Center to Outside 2.46”.” $ = $123.50 http://www.n-c.com/CatalogSet.aspx?p...=Tee&i=01FCF07
22.Vat Inline Valve
23. Granville – Phillips 275071 Convectron Gauge 1” Tubulation. $ = $88.76 http://www.recycledgoods.com/product...ubulation.html
24. Newport MVN-50 “Precision vertical linear translation stage” Metric Version $ = $425.00 http://www.lightglassoptics.com/Newp...age_p_286.html
25. Varian EYESYS Mini BA active high vacuum gauge. $ = $303.00 http://www.vacuum-zone.com/varian-ey...uge-p-820.html
26. Omega SA1-RTD Surface mount RTD temperature sensor. $ = $50.00 http://www.omega.com/ppt/pptsc.asp?ref=sa1-rtd
27. 3m Polyimide Film Tape 1205HD http://solutions9.3m.com/wps/portal/...be3ZCCJRL3W0gl
28. Koby vacuum pump charcoal trapping exhaust filter KA-1. $ = 2x $38.60 http://www.sisweb.com/catalog/08/F47
29. Alcatel oil mist eliminator OME-25-S for Alcatel Adixen KF25 outlet flange pumps. Part 104200. $ = $297.00 http://www.pchemlabs.com/product.asp?pid=2596
30. Nor-Cal Products ANC-NW-16-275 “NW-16 to 2.75OD CF conical adapter Nipple.” $ = 2x $81.00 http://www.n-c.com/CatalogSet.aspx?p...o_CF&i=01FTG03
31. Nor-Cal Products 275-D2 “2.75OD Double sided CF flange with two 1/8” NPT Holes.” $ = 2x $130.00 http://nor-calproducts.com/CatalogSe...pose&i=02FCF01 275-d2
32. Nor-Cal Products 275-D1V “2.75OD Double sided CF flange with 1/16” NPT hole and up-to-air valve.” $ = $365.00 http://nor-calproducts.com/CatalogSe...pose&i=02FCF01 275-D1V
33. Nor-Cal Products AN-NW-40-275 “NW-40 to 2.75OD CF straight adapter nipple.” $ = 3x $77.70 http://www.n-c.com/CatalogSet.aspx?p...o_CF&i=01FTG06
34. Edwards EMF3 A462-20-000 Oil mist filter. $ = $236.00 https://secure.sisweb.com/cart.htm?a...log%2F08%2FF49
35. Nor-Cal Products LH-075-24-2NW “NW-16 Thing wall SS flexible hose, 24” length.” $ = $152.25 http://www.n-c.com/CatalogSet.aspx?p...nge&i=01HOSE06
36. Ashcroft 0-30 PSI gauge and T fitting valve
37. Oriel large size optic holder 14427. $ = $50 http://www.rdysales.com/products/vib...l-holder-14427 and Oriel Instruments Part 16731 Undetermined.
38. Duniway Stockroom Corp. G-275 “Copper gaskets for 2.75OD CF Flange (OD 1.895”, ID 1.451”)” $ = 2x $1.70 http://www.who-sells-it.com/cy/duniw...-fullsize.html
39. Mitutoyo 110-502 NPT Micrometer Head. $ = $8x $195.00 http://www.scopeoptic.biz/servlet/Detail?no=192
40. Pfeiffer Vacuum TPR 280 Compact Pirani Gauge Sensor, Range 10-4 Torr, KF16 NW16, PN PTR26950A. $ = $391.00 http://www.pchemlabs.com/product.asp?pid=3412
41. Fluorinert FC-70 Electronic Liquid – Roughly Half Full http://www.sigmaaldrich.com/catalog/...0&QS=ON&F=SPEC
42. Silicon Solutions SS-35 Epoxy
43. SSupbo-8 Super smart pillow block. $ = 2x $98.83 https://www.motionindustries.com/mot...=500&width=600
44. Fluke Hart Scientific 1560 Black Stack. $ = $3160 http://www.instrumart.com/products/2...60-black-stack
And...
Fluke Hart Scientific 2562 Thermistor Scanner Module. $ = 2085.00
http://www.instrumart.com/products/2...scanner-module
45. National Instruments PCI-6034E-200kS/s, 16-bit 16-analog multifunction DAQ. $ = $999.00 http://sine.ni.com/nips/cds/view/p/lang/en/nid/11916
46. National Instruments PCI-6704 Static analog output 16-bit. $ = $1399.00 http://sine.ni.com/nips/cds/view/p/lang/en/nid/10705
47. Corcom 3EZLARS power entry module, plug, 3A. $ = $70.76 http://www.newark.com/te-connectivit...-3a/dp/52K4533
48. Corcom 5EHM4S Power line filters, foaston medical / flange. $ = $29.46 http://www.mouser.com/Search/m_Produ...0m2xt9XQwCrYg=
49. VSHolding EDR82848/2
50. Ultravolt 10A12-P4
51. Ultravolt 20A24-P30
52. Ultravolt 1A24-N20-F
53. Condor power supplies HAA524-A+ Linear and switching power supply. $ = $63.45 http://www.mouser.com/Search/m_Produ...Tu4HO1bbbYEA8G
54. Undetermined
55. Undetermined
56. 1x 4 way, 1x 2 way, 3x 1 way, 1x plastic ring = Electric / Coaxial passthroughs?
57. Huber + Suhner AG 3401.01.0005 Over voltage protector
58. Kings FP10548 Connector SHV 10kv straight PL
59. Solid Sealing Technology FA15166 “BNC Floating shield 500V, 3.6Amp, 0.094 304SS Conductor CF1.33 Flange without plug.” $ = 6x $284.00 http://www.solidsealing.com/parts/ac...ies.cfm?pid=80
60. Solid Sealing Technology KT13101 “Ground Shield Exposed 20kv, 16.5Amp, 0.094 Nickel Conductor CF1.33 Flange with plug.”$ = 6x $310.00 “4x with ring / 2x missing ring.” http://www.solidsealing.com/parts/listing.cfm?pcid=3
61. 4x Unknown Coaxial
62. Ring SKU: 754-7356 / MFG# 35405-1-103
63. Various large Conflat fittings. All SS, but bottom left is Aluminum
Photos Located at:
9. 2x MDC SS Rings
17. Undetermined
18. 3x Cords
22.Vat Inline Valve
And...
54. Undetermined
55. Undetermined
You might want to send emails to uhv (ultra-high vacuum) research groups, or companies that perform techniques under vacuum like Intel or other semiconductor companies.
It will be hard to sell the pumps without a warranty and no way to test if they work. Hope they sell quickly!
^ Thank you for that information. I was slightly hesitant to list all of this on here, but thought with such a diverse user base someone may have some sort of information on things.
I've been pitching the whole lot to surplus buyers and gotten a few nibbles. I will do some more research into those leads. Do you work in the surplus or scientific field? Again, thank you.
I am bringing this back up for a massive price drop. Currently, I am asking $5000 shipped in the Continental USA for these items. The Varian pumps are worth more than that alone. This is a great opportunity for someone in the vacuum or surplus industry to part this out and make a decent amount of money. If you have any questions feel free to shoot me a PM or email and I will do my best to respond as quickly as possible.
