Notices
Non-Automotive Classifieds Sell almost anything here, with the exception of firearms and ammo
[Socal]Professional Cerwin-Vega T36/750 horn loaded subs
Old 03-08-2006, 01:02 AM
leaftye's Avatar
Default [Socal]Professional Cerwin-Vega T36/750 horn loaded subs
Two Cerwin Vega T36 horn loaded subs available in San Diego for local pickup.
If you have been to a dance club, you've probably experienced this sub before. When I bought them, they were the top of the line. The specs still place them at the top even though they're no longer listed on the Cerwin Vega site. A few stores still sell them, so you can compare prices.
I used these as a mobile dj. I did church dances, a couple weddings, and a few military ceremonies. They're in great shape. They only real signs of wear are that it's noticable that these have been stacked and that I've used the rollers to roll, but these are both things that these cabinets are designed to do. Here's some info I've pulled off the web.....
Shoot me a PM if you're interested. I'm asking $1,500.00 for you to pick them up. They've been in a climate controlled storage unit for the past year.
> Eugene Leafty
Compact, Loud, Clean and Efficient
Imagination. Product excellence. Sound systems that enhance the musical experience. This is the essence of Gene Czerwinski's design philosophy since he founded Cerwin-Vega over 45 years ago.
The Intense! Series sound reinforcement loudspeakers combine this philosophy with current technology; high efficiency, enormous output and headroom, wide dynamic range, and very low distortion.
The Intense! T-36/750 subwoofer is compact, loud and clean. Featuring a larger radiating area than direct-radiating woofers, these horns will also array better, maintaining directivity or “throw” over a greater distance. (An array of four or more cabinets will give directivity down to 60 Hz.)
Comparison with the legendary L-36 Portable Earthquake horn is inevitable. This trapezoid-shaped cabinet is smaller (now 13” wide in the rear), yet the mouth size (6 square ft.) and flare cutoff frequency (32 Hz) are the same. Up to five cabinets can be packed side-by-side in a truck.
A new, highly-improved 18” driver was developed to enhance the performance of the T-36/750, and is the main reason the relatively compact T-36/750 outperforms the L-36PE in all parameters (particularly at 32 Hz).
To get more undistorted output, the excursion limits have been increased to 1 1/2" peak-to-peak through the use of a new edge suspension and spider. The diaphragm is Kapok and Kevlar; light yet very strong. The voice coil is very long yet the motor efficiency is three to five times greater than any 18” unit we know of—including the neodymium-iron-boron units claiming such advances.
Sustained high-power operation produces a lot of heat. A distinctive 1/8" thick metal front panel conducts heat out of the cabinet interior while also providing access to the L-1815 driver. This convex-shaped panel produces several other benefits:
# Longer horn path for low cutoff frequency
# Increased horn air chamber volume for lower system resonance
# Symmetrical loading of the subwoofer driver
# Increased compression loading of the driver (nearly 3:1) for higher efficiency and improved resistance to infrasonic damage (“dropped” microphone or tonearm)
The cabinet itself is constructed with 3/4" (18mm) SuperPly, an A-surface veneered void-free multiply material which is, pound for pound, stronger than conventional plywood. The result is a rugged, heavy-duty cabinet weighing less than 150 pounds—a relief for muscles and fly rigging.
Heavy-duty casters and handles make moving a one-man job, and the cabinet is equipped with both Neutrik Speakon and 1/4" phone jack (15 amp!) connections. The T-36/750F is also available with the unique MAN side attachments—the quickest and most secure flying system available.
Applications:
The T-36/750 subwoofer is designed for heavy duty use in high SPL, large venue environments.
Its high efficiency and directivity make it especially well suited for large indoor sound reinforcement where reverberation and articulation can be a problem.
When used in a vertical array of four or more cabinets and rigged overhead, the T-36/750 array can develop vertical directivity down to 60 Hz, directing the bass frequencies down to the listeners and away from the concrete walls and ceiling spaces common in arenas.
In smaller buildings or playback applications, cabinets can be located on the floor or in corners for increased subwoofer impact. For a flat response down to 32 Hz, a Cerwin-Vega F-1 processor should be used.
The T-36/750 is also the perfect system for outdoor applications.
The horn loading of the 18” woofer throws higher levels over greater distances than resonant direct radiator systems. Additionally, the drivers are not exposed to the elements— rain, wind, sun, flying bottles, etc.
When biamped (or triamped) with the Cerwin-Vega T-250 mid-high modules, a complete Intense! full-range system will produce louder, cleaner and more exciting results than most existing systems of twice the cost, weight or size. For portable sound reinforcement applications, factory-rigged sets of up to 16 cabinets per flying module are available.
All components are manufactured and assembled in our U.S. factory in California. Every Intense! system is rigorously tested for frequency response and freedom from distortion. These proof-of-performance test results are enclosed with every Intense! system shipped.
Quick Reply: [Socal]Professional Cerwin-Vega T36/750 horn loaded subs
