Hypertherm Plasma cutter
LS1TECH Sponsor
![](http://img.photobucket.com/albums/v739/red91z/907-1140496936691.jpg)
Hypertherm Powermax 1000, like new with only a dozen or so uses. Paid over 2000 from airgas. Will sell for 1600 plus shipping or can pick up in Ky.
Specs are below feel free to pm or call with questions.
270-792-2399
The Powermax1000 cuts over 50% faster than any other competitor tested on 3/4" (19 mm) mild steel.
Hand torch cut capacity
Recommended: up to 3/4" (19 mm) at cutting speeds of 22" (559 mm) per minute
Maximum: up to 1" (25 mm) at cutting speeds of 12" (304 mm) per minute
Severance: up to 1-1/4" (32 mm) at slow speed
Machine torch cut capacity
Recommended: up to 3/8" (10 mm)
Maximum: up to 1/2" (12 mm) (Cutting above requires an edge start)
Power supply features
60 amps, 8.4 kW output
Auto-voltage circuit
Boost Conditioner circuit
Standard CNC interface
Pilot arc controller with deactivation switch
Dual-threshold pilot arc circuit
