Sony XPLOD mono amp $85
Sony XPLOD mono amp $65
It was used for a few months, but basically like new sitting in the basement. First $65 takes it.
Here are some specs on it:
Product Type Amplifier
Recommended Use Car
Width 11.6 in
Depth 11.4 in
Height 2.2 in
Weight 6.2 lbs
Audio System
Response Bandwidth 20 - 300 Hz
Max Output Power / Channel Qty 800 Watts x 1
Continuous Power / Channel Qty 200 Watts x 1
Amplifier Output 1-channel
High Level Inputs Yes
Crossover Active crossover
Crossover Slope 12 dB/octave
Low Pass Frequencies 50 - 300 Hz
Bass Boost Frequency 40 Hz
Bass Boost Gain 0 to +10dB
Distortion Factor 0.2%
Amplifier Output Details 200 Watt - 4 Ohm - 20 - 100 Hz - THD 0.2% - 14.4V DC - 1 channel(s)
400 Watt - 2 Ohm - 20 - 100 Hz - THD 0.6% - 14.4V DC - 1 channel(s)
Additional Features Input level controls, gold plated connectors, thermal protection, subsonic filter, short circuit protection, DC offset protection
Connections
Connector Type 1 x audio line-in ( RCA phono x 2 )
1 x audio line-out ( RCA phono x 2 )
2 x speakers output ( screw-type )
Speakers input ( screw-type )
DC power input ( screw-type )
Recommended Use Car
Width 11.6 in
Depth 11.4 in
Height 2.2 in
Weight 6.2 lbs
Audio System
Connections
