System CDA-7998 Alpine and KX 600.4 Amp Trade
This is coming out of my SS and im looking to
TRADE it for a Xbox 360 or a Wii for the kids. Everthing is still in great condition. The HU does come with the remote as well. Here are the specs on the radio and the amp.....
The CDA-7998 CD receiver is a system-builder's dream come true! This MP3-playing Alpine has top-quality power supply and output capacitors for ultra-pure sound, plus gold-plated 4-volt preamp outputs that deliver a hot, clean signal to your amps and subs. (Component amps are required with this receiver — it doesn't have an internal amp).
The FantomFace XL faceplate is 30% larger than other single-DIN-sized receivers, but it takes up no more room in your dash. It's fully motorized (even the rotary control ****), and disappears when you power down, leaving nothing but a plain black panel to confound thieves.
Read More
Alpine's best and brightest BioLite® display will keep you "in-the-know" under any lighting condition. Its high-resolution graphics will amaze and amuse you. And switchable green or amber button illumination gives you more options to match your dash lighting.
Tone shaping possibilities are extensive. The Bass Engine® Pro section puts a 5-band parametric equalizer, 6-channel digital time correction, a 6-position crossover, plus subwoofer phase and level controls at your command.
Is your music sounding a little flat and lifeless? The remarkable Media Expander™ re-energizes MP3s, CDs, FM and XM Radio with three levels of enhancement — choose the one that pleases your ear.
Computer users can take advantage of Alpine's exclusive i-Personalize™ feature. Surf on over to Alpine's website, and you can create customized Bass Engine setups as well as a 3-line text greeting, burn the info to a disc, and upload it onto the CDA-7998!
Details:
FantomFace XL motorized stealth faceplate
BioLite high-resolution display
plays MP3 files on CD-R or CD-RW, plus audio CDs, CD-Rs, and CD-RWs
MaxTune SQ tuner
XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
Bass Engine Pro (5-band parametric EQ, 6-channel digital time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
Media Xpander
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
premium-quality power supply and output capacitors
gold-plated 4-volt front, rear, and subwoofer preamp outputs
i-Personalize
clock
wireless remote
component amp(s) required — no internal amp
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
Here are the specs on the Amp................
Versatility, power, and ultra-pure sound quality — Kicker's KX600.4 amplifier has it all! You can drive full-range speakers or components with four channels of clean-as-a-whistle 75 watts RMS power, or switch to 2-channel mode and push your subwoofers with 300 watts per channel. Protection circuits guard against overvoltage, reverse voltage, and overheating.
For some extra thump, adjust the bass boost for up to 18 dB of bass enhancement at 40 Hz. Front and rear variable crossovers (50-200 Hz at 12 dB per octave) set the amp up for full-range, high-pass, or low-pass operation. Speaker-level inputs are provided for connection to a factory system (or any receiver without preamp outputs).
Details:
2-, 3-, or 4-channel output
Tri-way capable (Tri-Way Crossover required)
75 watts RMS x 4 at 4 ohms
150 watts x 4 at 2 ohms
300 watts x 2 in bridged mode
speaker- and preamp-level inputs
front and rear high-pass/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
front/rear bass boost (0-18 dB at 40 Hz)
remote gain control with 25-foot cable
frequency response 20-20,000 Hz
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
unregulated Class A/B power supply offers a massive increase in power at 2 ohms
22-9/16"W x 2-5/8"H x 10-1/4"D
Here are the pictures. This is installed in my 2000 Camaro SS.
http://i23.photobucket.com/albums/b3...5/100_1440.jpg
http://i23.photobucket.com/albums/b3...5/100_1437.jpg
http://i23.photobucket.com/albums/b3...5/100_1436.jpg
http://i23.photobucket.com/albums/b3...5/100_1435.jpg
http://i23.photobucket.com/albums/b3...Picture791.jpg
http://i23.photobucket.com/albums/b3...Picture790.jpg
Read More
Details:
MaxTune SQ tuner
Media Xpander
i-Personalize
clock
wireless remote
Details:
