Optoma EP739 DLP Projector - HDTV
Barely Used, Only around 125 hours on the bulb! Always ran in Eco Mode.
Great HDTV Projector with 5,000 Hour Bulb Life and 2,500 lumens.
Payed $1250 a year ago.
Would like to get $500 Shipped OBO.
Comes with Carry Case, Cords, and Remote Control.
Info from Optoma Website.
The EP739 is one of Optoma’s most sturdy, practical and versatile digital projectors. From classrooms to boardrooms, the EP739 can handle a variety of applications and works well in all kinds of environments.
* True 1,024 x 768 XGA resolution with SXGA+ compression
* Bright 2,500 lumens rating with 2,000:1 high contrast ratio
* Amazing lamp life of 5,000 hours
* Fully HDTV compatible (720p, 1080i)
* Convenient DVI-HDCP, component, composite, and S-video input
* Weighs 5.3 pounds
* Adjustable cooling fan speed settings for higher altitude
* Ultra reliable DDR DLPTM technology from Texas Instruments for detailed graphics and video
Tech Specs:
A digital projector that features Texas Instrument's DLP technology / True 1024 x 768 Resolution / 2,200 ANSI Lumens / 2000:1 Contrast Ratio Resolution - 1024 x 768 XGA Contrast Ratio - 2000 - 1 (Full On/Full Off) 200 W SHP Lamp - approx. 2,000 hours of life Color Palette - 16.7 Million Throw Ratio - 2.0 - 2.4 - 1 Image Size (diagonal) - 24.6 to 246 Projection Distance - 3.9 to 32.8 ft. Projection Lens - F=2.4~2.65 with 1 - 1.2 Manual Zoom & Focus Multimedia Audio - built-in 3-watt speaker NTSC/PAL/SECAM Compatibility Horizontal Scan Rate - 15 to 100 kHz Vertical Refresh Rate - 43 to 120 Hz On-screen menu with adjustments in 11 languages I/O Connectors - DVI-I, VGA (for monitor loop through), S-Video, composite video, audio minijack, & RS-232 Unit Dimensions - 10.4 (w) x 4.11 (h) x 9.3 (d) Unit Weight - 5.3 lbs.
These are Photos of the same exact unit from the Optoma Website. If needed I can take pictures of the actual unit.
* Weighs 5.3 pounds
Tech Specs:
