Aeromotive Drag Race Electric Fuel Pump
Brand: Aeromotive
Product Line: Aeromotive A2000 Drag Racing Fuel Pumps
Part Type: Fuel Pumps, Electric External
Free Flow Rate: 350 gph
Maximum Pressure (psi): 30 psi
Inlet Size: -10 AN
Inlet Quantity: Single
Inlet Attachment: Female threads
Outlet Size: -10 AN
Outlet Quantity: Single
Outlet Attachment: Female threads
Quantity: Sold individually.
Notes: Has integrated bypass regulator with -8 AN return port.
Fuel Pump, Electric, A2000 Drag Race, External, Gas/Alcohol, Universal, Each
Ample fuel delivery for up to 2,000 hp.
These Aeromotive fuel pumps deliver 350 gph of fuel at free flow--enough for engines between 500 and 2,000 hp. They use a diaphragm-controlled regulator for even, reliable flow without sudden pressure spikes. The results are more consistent ETs and better overall performance. Compatible with gasoline and alcohol, the pumps feature a diaphragm bypass, -10 AN inlet and outlet ports, a -8 AN return port, a 1/8 in. NPT gauge port, and a proprietary shaft seal design.
***** I BOUGHT THIS NEW ABOUT 2 1/2 YEARS AGO. IT HAD A TOTAL OF 3 GALLONS GO THROUGH IT. THATS IT. IT HAS BEEN SITTING IN MY 69 CAMARO'S SEALED TRUNK EVER SINCE. THIS PUMP IS 100%. THIS PUMP COST $345.95 FROM SUMMIT. *****
$ 280 SHIPPED IN THE U.S.
Inlet Size: -10 AN
Outlet Size: -10 AN
