Denso High pressure 255+ In-Tank Universal Fuel pump- MORE RELIABLE THAN WALBORO!
WHY go DENSO over WALBORO?
We've found the walboro to be too inconsistent and to die out over time. As many of you know, in the supra community, its common to run dual walboro's. From experience, we've found the the walboro pumps to be inconsistent and were not able to keep up with high boost/ high fuel pressures with the factory 1:1 ratio.
"Toyota Supra Twin Turbo In Tank Pump
(Adj FPR required)
260 lph @43psi @12v 290 lph @43psi @14v
220 lph @58psi @12v 260 lph @58psi @14v "
I've personally ran dual walboros and have junked it for dual denso's. a local 2jz racer has gone through 12 walboro pumps till he was fed up and sold his triple walboro fuel pump sump setup to get triple densos. don't make the mistake of losing your motor to low fuel pressure/lean AFR's to save 100$
Description
Factory Toyota Supra Fuel Pump w/ Filter ( fits In-Tank)
The factory fuel pump flow is comparable or greater than a Walbro 255 with far superior reliability.
These are the same fuel pumps from a 93-98 Toyota Supra Twin Turbo, that have been used in many other high HP imports for years.
235.00 SHIPPED
Paypal id: Racerswholesale@gmail.com
GoogleCheckout Id: SPoolindevelopment@gmail.com
