rear gears?
i want to get into the mid 11s by the summer time, any help on getting me there will be appreciated
11.49 or faster will require a 6-point roll bar too.
I'm doing a gear change right now and the first number isn't a 3 or a 4.
Check out this thread taken from the 11 sec club
https://ls1tech.com/forums/11-second...-10-bolts.html
I had 3:73's and an Auburn pro put in mine 3 years ago with no issues. If I was able to do it over I would have spent the dough on something stronger.
Also if your looking for Mid 11's you will need a 3600 stall or bigger.
What gears are in your 10bolt now 3:23's?
1. Get rid of the crush sleeve and replace it with a solid spacer and shims. NW Diff can do this for you.
2. Put one of the cast aluminum covers like the TA. They support the rear caps and add quite a bit of strength. You could seel this when you upgraded.
I had a 230/232 on a 111. with a 3600 stall and I pulled a 11.9 at 115mph. That was with 2.73 gears. She still had some left in it.
228/228 would be a good cam. I believe Kraut has that cam in his GTO. When I was looking for a cam It was a toss up between the 228 and the torquer v2. But I ended up going with a TR224/227 .563/.569 114. And FWIW the LS1's like split pattern cams. If you stick with no smaller than 224 and no bigger than 230 for the street you cant go wrong
