Northwest Members WA, OR, ID, MT, WY, SD, ND
Computer chip keys?
Old Feb 7, 2009 | 07:06 PM
My1st Truck's Avatar
Default Computer chip keys?
My wife lost a set of keys for the Equinox. Anyone know anything about computer chip keys?
I see a bunch of blanks on ebay that say they have the chip, but won't it have to be programmed to match?
Old Feb 7, 2009 | 07:24 PM
99LSS1's Avatar
Yea, They have to be programed. I had to buy one for my Camaro when I bought it. The Stealership where I bought it programed it for free.
Old Feb 7, 2009 | 08:54 PM
firehawk618's Avatar
It all depends on what type of anti theft the Equinox uses. If you still have a set go ahead and order the ebay ones, have it cut and give it a whirl.
I had an 05 Colorado and it had anti theft but the resistor was built into the lock cylinder. A plain jane ebay key worked fine.
I have an 08 Chev Fullsize van and had the dealer make a non-chipped copy, won't start the van but works on the doors.
I don't remember the specific names of the types of anti theft used in the newest gm's but one of the types the resistor is in the lock cylinder only. Not the key. That type will allow you to get a non-chip key and use it. The other type has a transponder in the head of the key and will need to be programmed.
Worst that will happen if it's a chipped key and you use a non chipped is it won't start.
Oh yeah, look in the owners manual. It should state the type of anti theft used.
Old Feb 8, 2009 | 07:24 AM
99LSS1's Avatar
My bad!!! I was thinking about the key fob. I forgot they now come as a unit.
Old Feb 13, 2009 | 08:01 PM
iansane's Avatar
From the price of the key, it's got a chip in it. Retail ~$48. PT# 89024363. I've got a ton at work for $35 if you want, bring the VIN in and I'll have it cut for you. Programming the key is easy if you have at least one that's already programmed.
1. With a previously learned master key, turn ON the ignition, with the engine OFF.
2. Turn OFF the ignition and remove the key.
3. Within 10 seconds of turning OFF the ignition, insert the key to be learned and turn ON the ignition. The vehicle has now learned the new key.
That pretty much works on almost every newer GM rig.
HTH.
Old Feb 13, 2009 | 08:50 PM
HTH.
Where do you work? I am interested.
Old Feb 13, 2009 | 10:24 PM
HTH.
Would this procedure work with a 08 Express?
Old Feb 14, 2009 | 01:53 AM
iansane's Avatar
I'll check when I get to work tomorrow.
I work at Bruce Titus Chevrolet in the parts department. (North Tacoma).
Old Feb 14, 2009 | 11:53 AM
iansane's Avatar
Just checked, yup it does!
Old Feb 15, 2009 | 12:44 AM
Thank you very much
