Northwest Members WA, OR, ID, MT, WY, SD, ND
Tech Tip: Relatively cheap power
Old Mar 13, 2009 | 01:44 AM
tjwong's Avatar
Default Tech Tip: Relatively cheap power
Title says it all......well sorta. What I mean is that with relatively cheap parts one can make pretty decent power. Using a set of USED LS6 heads that were totally untouched other than upgraded springs and retainers and a good wash job to remove unwanted carbon build up, a smallish camshaft with 228 degrees of intake duration and the addition of a set of American Racing Headers with CATs. I was able to gain 86 WHP and 49 WTQ. The mule is a 2004 LS1 C5 Convertible. Gaining this power was breathing through a stock air box and a PAPER ELEMENT, and an untouch throttle body and the stock LS6 intake.
When I said cheap, I meant that anyone can just bolt on a set of used GM LS6 heads, add headers and a cam and get a real decent power gains. Used LS6 heads are available from $350 and up, this particular set was purchased by the owner from an earlier custome for $450 with only 25K miles on them. I doubt a set of higher priced aftermarket heads such as Trickflows or AFRs would have made much more if any more power. Not to mention for the DIY'er this is cheap power. If you have a shop do it, well its still cheap considering the price of the parts vs $2k + for AFR and other similar aftermarket heads.
File Type: pdf
Old Mar 13, 2009 | 10:26 AM
WAHUSKER's Avatar
Nice job Tom! I went the same route with heads. I bought some 317s for $325 & had Mike hog em out for me. I got about $1500 total in them, and would have payed twice that for name brands with the same stuff.
Old Mar 13, 2009 | 10:40 AM
Mikey 97Z M6's Avatar
I think you might have a nitrous leak down there at the shop Tom. Just kidding. Very nice numbers for such a modest setup.
Mike
Old Mar 13, 2009 | 12:20 PM
tjwong's Avatar
Here is a pic of the mules engine compartment as I degreed the camshaft in. This engine was in excellent shape, the pistons was in pristine shape after the carbon was chemically cleaned. I love my new cam degreeing tool, makes checking cam installation a breeze in any car or truck. With this cam the indicated intake lobe centerline is 108.6 degrees, spec for this particular cam is 109, not to shabby
Old Mar 13, 2009 | 12:52 PM
zlicious94's Avatar
Wow! Amazing #'s for that setup, nice work
Old Mar 13, 2009 | 02:33 PM
Ackattack1's Avatar
nice work! I may use a simlar set up when/if I build up my LS6 block. It needs a rebuild anyways.
I may throw on a supercharger onto the 5.3L instead...decisions decisions.
Old Mar 13, 2009 | 05:57 PM
98goldz28's Avatar
Looks good tom
Old Mar 14, 2009 | 02:43 PM
SsSteven's Avatar
Anyone got a set lot ls6 heads for sale??
Old Mar 14, 2009 | 05:06 PM
zlicious94's Avatar
I would definetly try and find some heads to run with your ms3! Is that the cam your going with I cant remember? H/C
Old Mar 14, 2009 | 05:31 PM
Spectre86's Avatar
mice job tom. how many miles were on the engine? were the heads milled at all for a higher CR?
Old Mar 14, 2009 | 05:34 PM
tjwong's Avatar
About 30k, and the heads were bone stock, no milling at all.
Old Mar 15, 2009 | 02:42 PM
HitmanLSX's Avatar
I'm thinkin about lookin for a cheap set of 243's... the 241's on mine had so much carbon build up I think even after cleaning it some of the valves aren't sealing all the way. still getting random misfires and need to change the O2's out again. I've welded up the cutouts they're causing too much trouble with fueling and O2's misreading. If anyone gets a line on a pair for $400 or less for LS6 heads let me know.
Old Mar 15, 2009 | 02:48 PM
firechicken76's Avatar
wow, looks like im gonna have to find some 243's to go with my x1 i just bought!
Old Mar 15, 2009 | 02:56 PM
thats also on a mustang dyno? so would there be like 20 more hp on a dynojet?
Old Mar 15, 2009 | 03:27 PM
tjwong's Avatar
Most likely it would be higher, but either way the gains that were acheived was on the same dyno, and that is what counts. I always perform a baseline test before the installation, that way I am comparing apples to apples. Incidentally that same car was dyno'd somewhere up north of me where it was tested on a Dyno-Dynamics chassis dyno, his baseline numbers were 20+ higher than what my dyno results were. Every dyno will be different, the important thing is to have it tested on the same dyno to make sure its not the different dyno that is giving different numbers.
Had I had the opportunity to install a set of CNC ported LS6 heads and port the intake and TB or add a FAST 90/90 I am willing to bet the numbers would have exceeded 440+
Old Mar 16, 2009 | 10:13 AM
Speed Density's Avatar
hashtagBMW
Looking good Tom! That degree'in tool looks real fancy.
