cooling issues
on it.normally the car runs around 185.210 does not bother me but 240ish kind of scares me.do ls2 water pumps flow more coolant?im wondering if it flows too much for a stock ls1 on hot days.any suggestions would be great,
thanks joe
Good luck.
Mike
fresh a/c charge may help a/c is not as cold as it should be.another issue that came to light tonight under high rpm decel getting off the free way a cloud of smoke litteraly came out my tail pipes when i got to the stop sign.i know ls1 use oil and some times pulling up to stop lights i smell burning oil slightly but this was real bad.like i was doing a small stand still burn out.any ideas? i put a new pcv in using valvoline 10w30 synthetic.hoping i dont need
a rebuild.
For the water temp, are you positive the fans are pulling a good amount of air? It almost sounds like the high speed fans are not working. When you engage the A/C, I believe the fans should automatically kick on to a higher speed. Could be an electrical, switch or relay issue there?
For the smoke, was it coming out of the tailpipe, or was it coming out from under the car? Could be an oil leak dripping onto a header/exhaust component. Or it could be valve seals going bad. Most LS1's in 4th gens have had ported heads (w/ new seals) installed before they reach 120k miles LOL....
I'd do a compression check just to be sure it's not a ring problem though.Mike
i have a feeling its the valve seals so now its time to save for the 5.3l
head package from patriot i want
.i dont know why my ex camaro owning freind said camaros are twitchy i have had no control issues with the car yet, even while side ways at about 30 mph
