Shock question
I'm trying to make the camaro nice to drive on the street, roughly stock, but able to be adjusted quickly at the track for good launches with the 5-speed and DR's. I can't afford qa1 goods, nor have I read much good about them on the street. Here's my idea, kyb gr2's on the front, and some acdelco air-adjustable rears. The ac's are made for towing, but I could air them up at different pressures to get a good launch, then deflate them for a soft ride on the street. Or should I do agx's all around, and a drag bag? Other ideas? I'm able to cut a 1.8 60's with the sixxer, and it'll be running in the 12's when I get the supercharger fitted in late august. Need some suspension work to get it where I want with my lack for power/torque, lol.
I'm running strano-bilsteins all around right now, and a ws6 front bar with a 17mm rear bar. I would sell the shocks since they only have 2 oil changes on them. I set the suspension up for auto-x, but I've yet to go cone diving, nor do I see myself doing it any time soon since I like doing club cruises and bracket racing instead. Also going to get a tunnel mounted tq arm to protect my little borg warner t5 (looking at the non adjustable jegster), and some poly ended lca's since I'm getting some hop still with my stockers stuffed with moog solid rubber bushings.
Help from you go fast fellows please
-Drag Bag /w hardware (lightly used)
-Poly LCA's. These are stock arms that have been boxed/welded for strength, and they have poly ends installed. These solved all my wheel hop issues from way bitd. Only reason I'm not using them now is because I needed some that I could adjust the length.
I would dissconnect that front sway bar for drag events. Anything you can do to get the front to come up quicker will help your launches. Maybe incorporate a quick dis-connect to the sway bar to make it easier to do at the track. I know the 4-wheeler guys have these for their rigs, maybe you could use something like that?
As for shocks, the fronts will need as little rebound dampening as possible, again to get that front to lift easier. I'm not too familiar with any of those that you listed.
Getting that T/A off the back of the trans is a great idea, especially on a T5. What rear gear ratio does your six have?
What kind of a tire do you plan to run on the back? Slick, DR or street tire? I have some 26-10.50-15 ET Streets I'll be listing for sale this spring. They have about 60-70% left on them. I'd make you a good deal if you're interested.
Mike
Gears in it now are 4.10's, auborn posi with worn clutches, need to find a different diff, but the one I want is expensive.
What's the reasoning behind disconnecting the front bar? I've read about people removing it, but I was always under the impression that they were cutting weight. Must have to do with how the car transfers weight. I know what you're referring to with the disconnects, was going to get some for my old 79 cherokee before I sold it. Might have to look into making a set for the Camaro.
Might have to snag those LCA's from you, need to make up my mind on the shocks before I get a bag though. I want to run a set of shocks all around that will be durable enough for the street, handle at least as well as factory, but still work well for drag (obviously making a sacrifice since the car is a driver).
The front sway bar has resistance against the rubber bushings on the chassis. This delays the response of the front end coming up. Any little bit helps, plus ditching the front sway also loses weight if it's completely gone. Any weight reduction off the nose is usually a good thing,,,, up to a point. Unless you're really into cornering, you probably won't even notice the front sway bar being gone. I haven't had one in my car since early 2000.
You can have those lca's if you want them. Consider it part of my "pay it forward" for 2010 lol.....
If you want the bag, how about 30.00?Mike
I'll probably keep some kind of bar on the front, just never know when I might need to make a maneuver on I5 do avoid the common idiot out there. It's my driver in the summer months, though that may change after someone smeared across my back bumper in the parking lot a few months ago.
Let me think on the arms and bag, need to get a game plan arranged first. As you can see, the car is a bit scattered in a build direction, and I'm the one that bought all the crap on it
http://www.summitracing.com/parts/MTT-3792/?image=large
edit for size - If I remember correctly they are 15"x8" with either 4 or 4 1/2" back spacing. I have a couple more pictures on my home computer showing all the measurements.
I'm open all week, what day could I drop by to pick them up?
Cody
