Northwest Members WA, OR, ID, MT, WY, SD, ND
Question
Old Jan 21, 2011 | 01:47 PM
tmoney223's Avatar
Default Question
I found a LQ9 long block motor with 160k on it for 950$. Hopefully I'll get it when I get my taxes back. The question is what would be the best thing to do with it. I wanna put a 150 shot on it. I don't know what head are on there. So should I port those or just by something else. Just some info would be cool.
Thanks.
Old Jan 21, 2011 | 02:24 PM
SalvageZ28's Avatar
Thanks.
Try find some 799 heads and get them milled and port them throw a Torquer 3 cam and that 150 shot and your well over 500 wheel horse
Old Jan 21, 2011 | 02:32 PM
tmoney223's Avatar
Well I was actually thinking of going with ESP cam. Todds car sure did com alive with there cam...799 heads are a good choice?..
Should I think about getting the block cleaned up at all?
Old Jan 21, 2011 | 02:36 PM
Tyler_LS1's Avatar
Sounds like a good find. I would go into the motor and make sure everything is good, btw it's EPS
Old Jan 21, 2011 | 02:41 PM
tmoney223's Avatar
Lol I knew that.... Yeah if I get it i will defiantly do that.
Old Jan 21, 2011 | 03:00 PM
tmoney223's Avatar
I don't get it. If the 799 heads are exactly the same as the 243's then why put a differnt casting number on them?
Old Jan 21, 2011 | 04:20 PM
Mikey 97Z M6's Avatar
GM's notorious for that ****....
I'd def go through the shortblock and make sure it's ready to go before you install it in your car.
Mike
Old Jan 21, 2011 | 04:36 PM
tmoney223's Avatar
Well it's going to be a spring and hopefully not to far into summer project.
I will definitely go through it.
Then I guess I should just look for both types of heads then.
I just hope it's still there when I get my taxes back, or there is another somewhere else if it's gone by then.
