Bent pushrod?
http://www.ebay.com/itm/271237990183...84.m1423.l2649
228/.585
228/.627
230/.590
230/.605
231/.614
231/.644
232/.595
234/.598
236/.609
Mike
Thanks!
228/.585
228/.627
230/.590
230/.605
231/.614
231/.644
232/.595
234/.598
236/.609
Mike
Thanks!
Mike
You were there when it came apart. Stock valve springs or aftermarket?
You guys determined the heads are not ported. How did you determine that?
What heads are they?
It's going to be really hard to tell if the springs went into coil bind with the heads off the car. It's hard to do ON the car with hydraulic lifters.
How did the lifter wheels look? If the cam looks bad, so will the lifters.
What kind of noise was it making?
On the tune, those issues can be fixed.
Since the OP is going to put the nitrous back on the car, I'd go with a cam of less than .600" lift, less than 230 intake duration and stick with 114 lobe sep. That lobe sep will make life easier on your tuner for sure. And yes, it's going to need a tune. And the specs I just mentioned make stock rockers the best choice. (I just lost a YT rocker last Sunday....fortunately, I was close to home).
Lastly, it's 2013 guys, how about some photos?
Hi Tom, how's things?
Ron
N2O brings it's own oxygen...you don't need a big cam.
Have you ever actually run a 250 shot before?
