Fuel Injectors
https://ls1tech.com/forums/sponsor-sales-specials/258134-fuel-injectors-sale.html
Prices look pretty good too. For most of us, the Bosch 30lb-ers would be fine (aka Ford SVO 30s). For whackos like sardog, the 42s are a good choice. You can go to this website & click on the fuel inj worksheet to determine what injector you should run for what hp you have. LS1s run about 58psi.
http://www.rceng.com/
Note - my stock 26.6lb-ers are running in the 100% duty cycle range at my hp rating, which is NOT good. You want to stay at 80% or less. Yes, they CAN handle it, but it can cause starvation at hi rpms, or worse - it can heat your fuel which contributes to detonation.
If you have a question, I would ask Ellis or Don B or Ryan or John B or Bill. They know more than I do about what the right choice is, AND why.
When you change the "Type' of injector I mean From the DELTEC-II you guys have now to a SVO/Bosch or other style. The reason is they do not react the same to a tune or pressure changes(not AS big on LS1). This means to get a GOOD reilution and dead on tune you need to spend weeks or monthes totally dailing in a Tune for an Injector.
Here is an example. On the Corvette we used MSD injectors. they are Rochestor injectors just like the Factory used on our cars. We dailed in the tune ,dead on , in 4 hours and five dyno runs
How many here can say that
BTW most go with the SVO / Bosch because they are dirt cheap
Motrons = 60# wow. I would like to know the duty clcle of my 42#'s. I think I have lots of room to grow with them.
Lucas is Disc also and can be has at good prices most of the time.
