Northwest Members WA, OR, ID, MT, WY, SD, ND
Drive Shaft Loop
Old Jan 25, 2005 | 05:04 PM
99LSS1's Avatar
Default Drive Shaft Loop
I want to get some input from you guys about which DSL I should go with. I don't want to spend a ton of money but will need to have one for racing this year. I do have bolt on SLP SFC's if that makes a difference, cause they bolt up to the same place. Thanks for your input.
Old Jan 25, 2005 | 05:07 PM
Tranzor's Avatar
Since you have the SLP SFCs, I'd just stick with an SLP loop... pretty much guaranteed to work with their own products. Plus it's the same price as all the others (around the $100 mark).
Old Jan 25, 2005 | 05:08 PM
Rokko's Avatar
Tech Addict
heres the one I use/have: http://www.spohn.net/category.cfm?categoryid=1164
I am getting the slp bolt in sfc's this year and was wondering how it would all bolt together at the DSL mount point.
Old Jan 25, 2005 | 07:21 PM
WAHUSKER's Avatar
I had the BMR DSL on my car with the SLP SFCs, and now I have the SLP because it doesn't hang as low.....
Old Jan 25, 2005 | 08:11 PM
krazzycowgirl's Avatar
I have two running around the house I dont know if they would work or not.
Old Jan 26, 2005 | 10:02 AM
sardog46's Avatar
i used the comp engenering one out of summit with the bolt in slp's, it works out great, plenty of clearence, best part is it is only 40$.
Old Jan 26, 2005 | 01:58 PM
Todd2001SS's Avatar
Tech Addict
I have the SLP DSL and it works great.
Old Jan 26, 2005 | 02:27 PM
Rockin C Racing's Avatar
For warning.... Some drive shaft loops are not located in the correct spot. I've known a few people that had SLP or Spohn and it did not meet NHRA specifications on its location. The loop must be with in 6 inches of the front yoke behind the tranny.
Old Jan 27, 2005 | 03:38 PM
SmokinWS6's Avatar
Do you have the regulations?? What about making your own DSL???
Old Jan 27, 2005 | 04:30 PM
I haven't received my 2005 rule book yet. And I've thrown away my old ones. When I get my new one, I would be more than happy to post up. I know I was hassled about this last year near the end of the season, yet the loop has been there for 3 years.
Old Jan 27, 2005 | 04:40 PM
What page would it be on I still have my 04 rule book. (heck most likely keep it until i die)
Old Jan 30, 2005 | 04:23 AM
Compstall's Avatar
The Jegster loop works too. It's less than $40 shipped and sits where it should be according to NHRA rules. No need for $100 driveshaft loop.
Old Jan 30, 2005 | 09:34 AM
TwoFast4Lv's Avatar
The rule reards "the loop must be no more then 6 inches from the CENTER of the u-joint.
I made the one on my car out of two lakewood kits and aMetco kit It is Legal
Old Jan 30, 2005 | 10:38 AM
Ryan K's Avatar
Pathological Modifier
I have used a few loops, the BEST one I have used is the one from Jegs. It has the best fit, it costs the least, and it weighs the least. Thats the only one I buy. And the clearance is the best for any exhaust.
Ryan
Old Feb 5, 2005 | 02:38 PM
99LSS1's Avatar
Thanks for all your input. And thanks Ryan. I ended up buying the one from Jegs and it just arrived. Can't wait to get it installed. It was only 60.00. Looks like it should be a pretty simple install. But thats what I said about my headers too.
Old Feb 5, 2005 | 05:37 PM
WAHUSKER's Avatar
Simple....drop the drive shaft, slide it on, bolt it in place. Note - it IS directional. It only fits one way....with the loop forward of the bolts as I recall. Confirmed, just looked. Loop in front of the bolt holes & offset to the pass side.
Old Feb 6, 2005 | 08:32 AM
99LSS1's Avatar
Thanks Mark, This one says I don't even have to drop the driveshaft. Bolts on around it. Might take care of that today.
Old Feb 6, 2005 | 03:07 PM
Tranzor's Avatar
yeah, I wish I had gotten a two piece unit like that... the BMR did not fit with the TSP catted y-pipe. But that's ok... it fits now. It's a wonder what a grinder and a few locking washers will do.
Old Feb 6, 2005 | 03:41 PM
Todd2001SS's Avatar
Tech Addict
I was a little intimidated but taking the DS off was easy.
