Northwest Members WA, OR, ID, MT, WY, SD, ND
LS1 exhaust ?
Old Feb 2, 2005 | 10:41 PM
kcsoz20's Avatar
Question LS1 exhaust ?
Hey all,
My buddy has a 98 T.A. Apparently the CATS are setting SES!
He wants to go headers and !cats.
What all is involved. Will he need O2 sims? I suggested KOOKS headers to him.
Will he need to change PCM to go !AIR on a longtube install?
Thanks,
Ken
Old Feb 2, 2005 | 10:47 PM
Poik's Avatar
He could buy O2 sims OR he could just get them programmed out in the computer. I am 99% sure you have to program out the AIR and EGR to take them off without throwing a code.
Old Feb 2, 2005 | 11:47 PM
Tranzor's Avatar
You can program out the need for o2 sims and the codes for the AIR pump so it can be removed as well.
If he's not able to get programming right away, he will probably just want to get the sims to avoid the SES light, and not remove the AIR pump until he can program the code out.
Old Feb 3, 2005 | 06:35 AM
mykdiver's Avatar
If you get it reprogrammed you might as well do the !EGR, !AIR, and !O2 sensors, get your rev limiter raised, get your top speed limiter raised, change the temps at which your fans come on. etc.....
Old Feb 3, 2005 | 07:59 AM
WAHUSKER's Avatar
I think Ellis is the only one around that can tune a 98's VCM.
Kooks, QTPs, PPCs or FLPs are the 4 Grotty type headers. You can't go wrong with those for fit or performacne. Cost on the other hand..... If he wants a more reasonably priced header look into PaceSetter or the new Eldebrocks. Do NOT buy SLP.
If you plan to install them yourself, there are good instructions on installuniversity.com or ls1howto.com or both. And I can type up some tricks / tips for you. Tho I've never done a 98.....
Old Feb 3, 2005 | 11:51 AM
NataSS Inc's Avatar
dont forget some O2 extensions for the front sensors.
Old Feb 3, 2005 | 12:21 PM
kcsoz20's Avatar
Thumbs up Thanks...
Allright all, I will pass on all suggestions and info to him!
Ken
Old Feb 3, 2005 | 05:27 PM
mykdiver's Avatar
That is locally, but he can send his PCM off and get it tuned. Or if you are talking about needing tuning more often buy in on Ryan or Brian's LS1 Edit.
