Northwest Members WA, OR, ID, MT, WY, SD, ND
rocker arms
Old Jun 7, 2005 | 09:45 AM
slowpokez28's Avatar
Default rocker arms
I was speaking with the shop mechanic today(he also owns a speed shop)
He was telling me that comp cams cam out with some rockers arms at idle they are 1.74 then at wot they go to a 1.85.
I cant find any info on such lifters I'm not thinking of doing this to my car if they don't exist i want to call his bullshit, If they do i want info on them since they sound interesting.I guess they were made to help a ls1 idle and for the guys that want a sleeper car
Old Jun 7, 2005 | 09:51 AM
Rokko's Avatar
Tech Addict
They are Crane Rockers.
http://www.cranecams.com/?show=newPr...126e2131c8b0d7
Old Jun 7, 2005 | 10:11 AM
Thank you LOL so they do exist I thought the guy was feeding me a line of ****...thanks for the link
Old Jun 7, 2005 | 10:26 AM
Rokko's Avatar
Tech Addict
No prob. They actually start out at 1.8 then revert back to 1.72 at around .300" lift. Then they go back to 1.8 on the backside ramp at around .300
Pretty slick upgrade for a stock cammed car.
Old Jun 7, 2005 | 10:41 AM
They sound like it. stock cams would be like a baby cam with those.When i get my wife her camaro i may just slide them in save myself money and alot of headaches.
My ls1 just got over the burps and tantrum of having a cam upgrade so no way in hell i plan to touch that motor. it is going on 3 days running just smokin *** hot.
so what would the lift be on a stock cam at WOT I don't even know what a stock cam is never paid any attention.
Old Jun 7, 2005 | 11:30 AM
Rokko's Avatar
Tech Addict
might be close to .500 on the exhaust side, but I doubt it. lift is the same at all throttle positions.
the stock cam in my car has these specs:
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
with those specs the lift under .300" is going to be accelerated to .507 on the exhaust side and .494 on the intake side.
Old Jun 7, 2005 | 12:10 PM
narcszm's Avatar
you can call BS on the fact that they change rate dependent upon throttle application. Likely just his misunderstanding of the technology. As you've already figured out, they change ramp rate independent of RPM and throttle application.
Old Jun 7, 2005 | 10:53 PM
WAHUSKER's Avatar
Your 99 cam had .495 lift if I recall correctly.
Old Jun 7, 2005 | 11:37 PM
Thanks i needed that info. Looking at 2 cars right now for my wife a jet black 95 with t-tops 6 speed. And the other is a 00 pewter T/a with a 6 speed coupe, neither car has been modified.so knowing stock specs comes in handy
Old Jun 8, 2005 | 03:07 AM
jimbob's Avatar
Hello........Ok guys...it's just a marketing ploy.....I mean seriously come on....
Our valve train is not in a true verticle position (from the lifter)....Even if it was the rockers we use need to swing on an axis were the push rod contacts the rockers, in order to keep the rocker ratio constant through it's arc. Almost all rockers (including ours) are varitable ratio....The ratio that is stamped on a aftermarket rockers is the minumum ratio through it's arc. Crane cams can kiss my *** from now on, with this BS ploy Crane cams............... for general knowledge here.....the stock stamped small block chevy 1.5 ratio...usually measures out to 1.38 to 1.46 ratio through it's arc....
Oh, I guess crane cams can grind a specific cam for the small block chevy "Stock" varitable rocker too........what's next cam specific grinds with this OLD...I mean new technology......
Jimbob
Old Jun 8, 2005 | 08:09 AM
WAHUSKER's Avatar
Hey Jimbob, it's better than their "NEW" beehive technology for valve springs!
That said, you need to talk to Ellis before you do anything like this slowpoke. Stock rockers are 1.7 ratio. I am running 1.8s. But most aftermarket rockers, while 'better' than the stock ones, can create issues of their own. Like not clearing the valve covers, or making the valves hit the pistons, or insignificant things like that.
Old Jun 8, 2005 | 09:25 AM
NautyAngel's Avatar
I read a bunch of stuff on these and also the patriot performance aluminium extruded unimpressed with either one after a full investigation into them....after all this was just for knowledge purposes only. and of course i will talk to ellis before anything is done to any car i own except the durango lol
I have came to the conclusion as hard as it is the next car will just have to have a cam replace. Not as beefy as mine cant have my wife with a faster ride
I'm looking high and low into a new car the durango is **** up. the local machine shop wants 500 per head to resurface and install new valves and seats.This does not include if any cracks are found.The bottom end needs work too so i really only have a few options left at this point and only 2 weeks to figure it out and get it done.
damnit logged in as my wife again
Slowpokez
Old Jun 8, 2005 | 10:58 AM
Rottluver's Avatar
I may be a bit biased here, and I mean ABSOLUTELY no disrespect to anyone, but I would pick the '00 TA over the older Z.......unless you plan on totally tearing into the car when you get it, I would say the newer car is a better way to go.
Just my $.02
Old Jun 8, 2005 | 05:53 PM
Just my $.02
The T/A was already high on my list..I think i need to drive yours to get the feel of one, I heard the are different creatures than a camaro
Old Jun 8, 2005 | 06:23 PM
Rottluver's Avatar
You are about as subtle as a freight train
Old Jun 8, 2005 | 06:45 PM
HitmanLSX's Avatar
that and rockers with certain cams aren't a good thing
Old Jun 8, 2005 | 07:03 PM
Tell me about it the wrong rocker/Cam setup can wreck havoc on a otherwise good engine.When i was doing hi-performance stuff 10-12 yrs ago
threw my valves into the pistons due to wrong setup...(Have never picked up a wrench to work on a v8 since .My durango is still sitting in the garage waiting for love LOL)so fear is what stops me from working on my LS1 That is what i pay ellis for .Like my knock sensor need to be done I won't even do that(I know iknow get over it you wussy)
Old Jul 2, 2005 | 06:33 PM
mrr23's Avatar
i did the vinci/crane 1.8 accelerated lift rockers in the wife's 99 formula along with the dual springs. here's the results.
dyno 9 before
dyno 11 500 miles later
dyno 14 10 months later
