Battery Relocation Kit
I have an Optima Red Top battery, so that part is good to go....
Anybody know the NHRA rules about at what ET you need a shut-off switch? Or is it an always-always thing if you relocate the batt?
For road racing the cut off can be anywhere as long as there is a "power" sticker ourside the car very close to the location of the cutoff.
I don't know if that changes with a batt-relocation though... my quick reference sheet says to check section 8:4 of the NHRA rulebook concerning the cut-off switch for any exceptions to the rule. Unfortunately, I don't have the rulebook...
Master cutoff switch is mandatory when battery is relocated. An electrical power cutoff switch (only one) must be installed in the REARMOST part of each vehicle and be easily accessible from the outside of the car body. The cutoff switch must be connected to the POSITIVE side of the electrical system and must stop all electrical functions. The off position must be clearly indicated with the word OFF. If the switch is push/pull type, push must be the action of shutting off the electrical system, pull to turn on. Any rods of cables used to activate the switch must be minimum 1/8 inch diameter. Plastic or keyed switches prohibited.
