rear-end local?
Invalueable info here guys, thanks!!
Dan will take car you of you Man
he said you had called today.Tom does great Work that is why I send you souther boys to him
BUT some one has to pay the bills around this place!
Car runs great now though, a definate difference in performance. Need to fill the bottle but I'm not sure its a good idea with the rear being the way it is. Was pretty freaking loud on the way home
. I know putting the interior of the car back in will help a little but not that much
it not a high pitch whine now as much as a low tone growl, kind of a metal knashing metal scraping excuse to have the stereo up to loud, 373's mr tom please
Sorry about the rear end. I think the extensive time that the pinion was loose probably caused irrepairable damage to the gears. Running a few passes on a load bearing dynanometer was just the straw that broke the camels back
At least we hit the target Hp numbers you were looking for and I am glad to hear drivability is improved as well. I will check on a set of 373 gears and all the bearings as well. I am sure that with all the metal floating around, all the bearings will be needing replacement. If the connector did not match then you had the wrong harness or the sender had been changed at some point.
All '94 C4's have a 4-position connector for the fuel sender.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
At least we hit the target Hp numbers you were looking for and I am glad to hear drivability is improved as well. I will check on a set of 373 gears and all the bearings as well. I am sure that with all the metal floating around, all the bearings will be needing replacement.The Best V8 Stories One Small Block at Time
