rear-end local?
Get a good 9 inch or 12 bolt. That's what I will be doing when my warranty expires.
Well... I can setup gears. Started setting them up when I was 13 or so. Problem is I do not have all the stuff to do it and I am so **** about it I just sub it out to someone I really trust
Dan has done a great job on all the gears I have had in my car in the past eight years or so. He stands behind his work and does his damn best to get it right the first time. BTW On the one you have there if it has a crush sleeve yes the rear end has to come back apart. If they used spacers you have a shot but I am guessing the gears may be hurt. The nut only holds as much tention as the crush sleeve will let it. Either the sleeve was never crushed or shock loads over crushed it and gears are
I do Sell Dans Services through 'Speed Secrets' when needed
He only lives a few miles from us. I have been known to take cars in after hours and weekends for him.Yeah I installed my Racetronix stuff this week as well. I have done a few, always a PITA. Minw actually went fairly easy
Then again the battery and main feed is in the trunk
Tommy's work is great, I'm glad to get his hands on the car.
I'll call on tuesday about dropping it off to finish.
They did my rear end in the Formula 2 years ago, and it's holding up pretty nicely. I'm real happy with it, and they do a kickass job. Quick, too!
Stop by again, lots have changed at the shop. I canned my worthless parther last January, about all he was good at was being a parasite on the business.Ellis, I am working on getting the engine completed. I got the engine back for the TA that you saw in the shop. Finally TIG welded the guide plates so the engine can be finalized and then ran in on the engine dyne. Then it goes into the car so I can complete wiring and fire it up
The machine shop is going to complete my short block in the next week or so. Then I need to buy a few more parts as cash comes in. Damn its always about more cash
I need to take on a part time engineering job to make extra dough so I can get my own stuff done.
AND dont be confused here either, I added up all my parts slips last night.
Tom is only the second person I've paid to work on the car and he isnt expensive, but a very good mech. The other was the dealer for the clutch, if I had known about Wong Performance it would have been him instead. The quality of his work is really top notch. I'm working on getting the bottle mounted today, I can run the line on the inside as well to save you some time, where should I put it? I'll call you.
