*hangs head* Cap'n I needed more power!
Originally Posted by NVME88GT
Did that guy in Mt. Verlington that was supposed to be building the bad dude DSM ever get his junk finished? I need to race.
He's from Bellingham and last I heard he was getting close. You can race my raggedy assed Chevelle when I break it in.
Forge the bottle, go get yourself a good cam. Its like having the bottle all the time. If he didnt pull on you very bad a mid size cam would have at least kept you door to door with him.
Originally Posted by rookiels1
well I'm lookin at the torquer 2 232/234, .595"/.598", 112 LSA (or is the overlap too much for nitrous?) and when I do to the stroker probably the Magic Stick v.3 237/242, .603"/.609", 113 LSA. What about the 233/239 v.2 233/239, .598"/.603", 113 LSA
Originally Posted by Rottluver
A 232/234 on a 346 LS1? DAMN BOY!!!!! Talk about having some lope in your idle.
MS3????
I didn't say ya couldn't use it, just said it would have a wicked lope. And would take some serious skills (ala Ellis) at tuning it so you could drive it without stalling out all the time I would think.
Not going to get into to much here but dont get all caught up on peak hp numbers by the supposed better bigger cams. One person stated that a good cam is like nitrous all the time. Agreeable there but be careful with what cam your going with. What good is the hp if it comes to high in the rpm cycle? Sure if your going to be at the track all the time and running the car at 6k plus rpms you'll benefit from the big cam but if your looking at a daily driver think differently. Even before my heads my cam out put pulled the famed FM13 all the way to 5800 rpms. I say this again because its hp and tq all in the usable range of daily driving. The fm13 is like a 232/230 or something and yet it does not produce the power until over 6000 rpms. TSP cams have never produced as well as the others either. Look at dyno's and do a lot of research before you slect a cam. Then look at having a custom cam ground as well, its only $150 more than an off the shelf cam. People get caught up in the bigger is better, but ist not always the case. It's all dependant upon the use. high stall track= big cam , daily driver = mid range or smaller cam (it gives more power).
Well tell him to hurry up! He said it was going to be finished like 4 months ago. I know how that goes though.
You know I'm always down to race you or whoever. Just give me a call, man!
yeah the reason I was going with the torquer mostly was after talking with TSP it's what they recommended for road course/auto-x work because of the bottom end on it to pull out of the corners. I'll probably end up going with a custom cam
#32
When I talked to Alan, I told him I had the TSP 231/237 and was looking for a cam that peaked a little bit earlier, carried the rpms just as far, had at least the same peak HP if not a little more, and produce a better torque curve.
He suggested the F13... after the dyno, it did EXACTLY what he said it would. Produced 5-10 rwhp more than the 231/237 at peak, it peaked at 6100 rpms instead of 6300, it carried the powerband from there to 7k without significant loss, and produced a better torque curve (15 more rwtq or so).
The man knows his stuff, that's for sure...
#33
Originally Posted by Tranzor_Z28
Talk to Alan Futral... he'll set you up with a nice cam for your needs, and they go through Cam Motion for their grinds.
#34
Originally Posted by 99blancoSS
While I agree with you about the cam comparisons the fm13 still doesnt produce as much torque as the tr224 or hp under the curve. For all the talk about the fm13 its not any better unless your running it above 5800 rpms. Is he going to run his car at that rpm? If he is then the fm13 is a good cam for that use but if he's not looking for a number on a signature and wants usable power on the street then the tr224 on a 112 lsa is the way to go. Even at the track it produces 12.2 in a cam only car w/stall. One of your members on your list of times. Thats why the question.. what are you doing with the car? Heck you can go with an fm13 its almost as good as a tr224 on street, but not quite.
But you are right, its what you want to do with the car... do you want a mean idle, do you want a cam that will peak over 6000 rpms and has the ability to carry those rpms to 7k with no drop off? Do you have the need for something like that? Do you plan on having ported heads in the future, which will extend the benefit of the bigger cam?
#35
It all depends on the setup, dude... its hard to compare cars unless they have exactly the same setup, run at the exact same time, in the exact same conditions, with the exact same driver. I'd be willing to bet that the same car with a 224 cam would run faster with an F13 cam in it, all things being equal. In fact, if someone wants to do the R&R work, I'd be more than happy to test that theory... run my car with a 224 at the track, then run it with the F13 and compare, without changing anything else to the setup.
