View Poll Results: Clutch
McLeod Twin Disc
13
50.00%
Textralia
9
34.62%
Other
4
15.38%
Voters: 26. You may not vote on this poll
Clutch opinions
Originally Posted by TwoFast4Lv
Actually it is because they have no stored energy for take off's
Robert
I went the inexpensive route with a ram non hd (500hp) clutch with the stock flywheel turned by a local machine shop. It is holding great so far. I want to say I had it back on the road with 300 to 400 dollars invested ( I can't remember the exact cost)
I have the Mcleod and so far I love it. I have to agree with tranzor about how violent it can be on your drivetrain. I have upgraded everything from the motor back in hopes of keeping the clutch from breaking something. But even with all that done when I'm on it hard and speed shift at the top of a gear, it grabs so hard that the drivetrain makes a violent metalic whoosh sound as the clutch engages. Kinda scary!!
I have already gone through 3 other clutches and this one kicks ***. I would recommend it and have to say that it is very streetable but has a heavier pedal pressure than most!
Just my .02 cents from my experiences.
Originally Posted by WAHUSKER
You will certainly need the slave mod Josh. Bill was already having issues shifting.....
Wow all I get when I drop second hard is a slight decrease in acceleration as the back tires spin for a second before they grap again. No noises, just a slight kick in the rear as it straightens itself out again. Had someone yesterday try and pull the old rolling drag run from a light to get in front of me yesterday. I wound it out in 1st slowly at first to give them hope of beating me then hit second at 6k rpms and left about 20ft. Needless to say he wasnt getting in front of me. Tex has taken all I can give it so far. I dont have a sticking problem and havent done the mod either, but am thinking about it just for something to do. Not trying to coherce anyone here either just reporting my experiences with the tex so far.
So is your engine ok? Last we heard it may be dead
GO HAWKS
Time to get in da shower and head over to the SB BBQ!! Baked some brownies for dessert, got my bottle , good luck seahawks fans I'm with ya today!
Remember, if going Textraila, they rec no drill mod, not needed, and they use the Z06 slave and factory master. Using the Mcleod master can cause issues also, and IIRC Textraila says stay away from that also. A complete package that works, for sure. Has held upto 1000rwhp.
Robert
Robert
#32
slave mod or drill mod? I think the 01's already have the updated slave and if I remember correctly the vette slave is different than the f-body slave? but I could be wrong. and yes I've ran into the clutch issue did on my old one as well. doesn't happen on the 1-2 just the 2-3-4 but will effect all shifting afterwards for about 5-10 minutes depending on how you drive. Heat issue?
#33
#34
Imo, the sticking clutch pedal is a pressure plate issue and not hydraulics. I am still using unmodded hyd and with Textraila clutch and pressure plate no sticking pedal. However, i was having this problem with stock press plate/clutch disc. Also, why would a good working clutch set-up rec stock hydraulics, and in fact send a new stock slave and rec no modding, because problem is solved with new press plate/disc. Yes, the late f-bod and Z06 slaves are the same, except lenght of bleeder is model specific. Aussie clutch came with a Z06/f-bod slave, new Zo6 flywheel and aussie disc/pressure plate.
Robert
Robert
#35
Robert
Robert
Ok I read somewhere that stated one guys sticking pedal was due to a warped press plate. Which seems to be common with F-bod's with headers. To avoid this happening on the Tex would wrapping the headers be a good idea?
#37
Was fine after I stopped making passes.
edit: This is just general talk about F-Bod clutches, not about Bill's old car/Josh's new car's problem.
#38
I spent alot of time in that car and IMO the only thing that could explain it's behavior is that at higher rpms the clutch fingers flex and push the slave back into it's bore. I firmly believe it's a pressure plate issue.
#39
It is most definately a PP issue
#40
i use mcleods in both my cars.never had any problems.the vert put down 700rwhp on et streets.don't believe any single disk will match that.
we got some pretty fast cars on the east side. maybe we get together and run you west side boys? any takers?
matt
matt
