Bad Cat/s??
I can barely hear the sound when I pop the hood and try to listen but it does get very loud when I walk around the car and get to about the middle of the car, driver's side back to the left rear wheel well.......someone suggested that my cat went bad. Any other suggestions or agreements with that one?
Also the sound does NOT change or get better or worse with a change in RPM, I usually hear it most upon initial start-up and at idle at a stop light or as I am just taking off in 1st gear, etc. I can faintly hear it while I am driving (most of the time) but it seems to be at it's worst when I start up the car.
TIA.
Sounds like a cat to me. If it was piston slap (or other engine problems) you'd hear it more when you opened the hood. If it was the exh hitting, you hear it worse when you let the clutch out
From what you are saying it sounds like a cat. You have stock exhaust? If so I have a cat
Need to get them re-worked anyway since they scrape a LOT & hang WAYYYY too low. Just didn't wanna spend the $$ right now.But thanks just the same.
with hammers and stuff.
Seriously, thanks, I will put her up on the ramps tomorrow and see........it was weird, when I went to the gym today......no noise at startup and almost no rattles at all the entire trip.......coming home was a whole other story though...
