Northwest Members WA, OR, ID, MT, WY, SD, ND
Fuel line woes
Old Feb 5, 2006 | 01:20 AM
WAHUSKER's Avatar
Default Fuel line woes
Well, that mass of fittings you gave me should have worked Ellis. But as it turns out it didn't. All the threads were right, but the fuel line ATI gives you needs a tube to stick into the fitting to seal.
So I need to make a 10' return line to get this thing finished. I'll order the 20' kit from Summit Monday unless I can find one locally tomorrow morning (& then you'll end up with 10' of line to go with the fittings I gave you....) but I will likely need the parts you gave me to hook up to the factory stuff.
I'll say one thing, the ATI pump makes a NICE puddle on the floor when 1 line doesn't seal.
Old Feb 5, 2006 | 01:27 AM
HitmanLSX's Avatar
that sucks... bet that smelled good...
Old Feb 5, 2006 | 01:32 AM
WAHUSKER's Avatar
Yeah, not sure how long it will be before I feel comfortable closing the garage door with a gas furnace. Got a fan running now......
Old Feb 5, 2006 | 01:39 AM
howierd42's Avatar
Man, this seems to be a comedy of errors. It may be next year before you actually get to put that thing on the track.
Old Feb 5, 2006 | 02:26 AM
TwoFast4Lv's Avatar
Hey I had an idea. could you snap a quick pick for me of the leaking parts
Old Feb 5, 2006 | 11:42 AM
Steve Goodwin's Avatar
Being fast ain't easy
It will be worth it in the long run.
Old Feb 5, 2006 | 12:33 PM
WAHUSKER's Avatar
After getting the line off the car I think I need a 4 AN male to make this work.....I found an Aeroquip -6 AN female to -4 AN male adapter that should solve my problem. Just gotta get one now.
Old Feb 5, 2006 | 10:29 PM
WAHUSKER's Avatar
No joy Ellis. Not sure what this morphedite POS line is that ATI gives you, but nothing seems to fit it. FRACK
