Hey Ellis, does this sound right?
I went into LS1Edit and took at look at where the torque management settings were on my car... and I've done a little editing based off an online FAQ I found, just wanted to make sure that what I did is kosher..
I dunno how this translates to HPTuners, but I would think the table names are the same... anyway.. here's what I edited..
Trans Cal -> A4 Shift Firmness -> Torque Reduction -> All values zero
Trans Cal -> A4 Shift Firmness -> Upshift Torque Reduction -> All values zero
Engine -> Ignition -> Max Torque -> changed from 350 to 639
Engine -> Ignition -> Torque reduction -> All values zero
Originally Posted by TwoFast4Lv
Looks good Zeke. Do not forget the IAT table I was telling you about ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Also... In my Mid RPM Misfire table, there's a lot of values that aren't 32767... should I clear all these out and set them to 32767?
