Guesses?
Should I up the rev limiter to say 6500 rpms and shift at 6300 rpms instead?
Theres got to be a reason for my poor track times
Oh ya threw an SES light but I'm pretty sure thats because I removed the secondary air system.
2.1 isn't too bad for normal street tires, especially if it's lowered without LCA relocation brackets etc..
Aside from that, unless your car is a complete TANK, you should be trapping 116+mph.
Also, and this may seem crazy, but I had an issue with my floor mat one time. It was getting under the throttle pedal and not letting the car get to WOT.... just something I thought I mention. Couldn't figue out why the hell my car was only trapping at 109 when I was used to trapping at 114 lol...
You should be side stepping the clutch around 5K with good stickies to get a good 60ft in a stick car.
What rear do you have? The above should only be done with a 12bolt or 9inch.
Shifting way to early too. Take it to at least 6400. My mostly stocker shifts at 6k.
I'll raise my rev limiter and shift at a higher point.
I'm having traction issues off the line but most people think I should still be trapping at a higher mph for the power my car has. I'll see what happens with the shift point change. At least I'm consistent in my times and speed which has to indicate some consistency to my driving. Slow or not I'm consistent.
Honestly I'm not that pissed about the et ( I know 60's will fix the et) its the trap speed that bothers me. It should be higher is what is felt by almost everyone I talk to.
So thats got to be either a problem with the car or my shifting point. I nailed all my shifts Sat night. My slips are all within 2/10's of each other. Thats not bad driving with just a shift light.
Yes I'm taking my foot off the gas to shift. I just cant make myself keep it floored and bang thru the gears.
So what your all saying is that my 60's are the issue and trap speed is ok. Even for a car with as much power as I have? Its 410 on Toms Mustang dyno which is about 440 or so on a dynojet?
I have an 86 Caprice wagon 15 inch tires. Can I use those rims for some et streets? I'm broke and cant afford to buy anything these days.
Overall though, your speed and et sound in check with each other......just not for the power level you have. Figure out what's wrong with the car.
The car still pulls pretty damn hard so I guess I can drive it for a long time the way it is. Sooner or later something worse might happen though? Tom said something about rings maybe.
at 13.2 13.3 13.4
