GURU's come inside..........
I wanted to swap my LS6 steam tube out to the LS1 "X" style lines to improve the cooling in cylinder #7 and posibly #8, and upgrade the to the LS6 PCV system while incorperating a catch can.
Does anyone know why when doing the LS1 to LS6 PCV conversion, why the LS6 valley cover will not allow the LS1 steam tube to fit? Or has anyone done the LS1 steam tube inbetween the LS6 valley cover and LS6 intake manifold?
Apparently all you have to do to make the LS1 "X" style steam tube to fit under the LS6 intake manifold is to grind down some of the stiffening ribs on the bottom side of the intake. I'm assuming that the newer LS6 valley cover also impedes the lines some how. But I don't know......
Oh, and by the way Cory could get you an extra 5+RWHP with his port work on that manifold....
But what about the LS6 valley cover? Will it get in the way of the LS1 coolant tube?
Perry may have further info on this, as he had a little on us about the PVC and seemed to be schooled in this area.
Robert
Robert
There might be away to re-route the coolant lines though. Someone posted in another one of my threads about how he used two of the LS6 style coolant tubes in the front AND the back of the block. And he routed some tubing around the manifold to conect the two coolant tubes. It sounds odd to me, but it might just work. I asked him to post up some pics. As of tonight he just posted up a drawing he made with microsoft paint.
If I sell my LS6 intake I'll let you know if it works or not....
I remember seeing a pic of the LS6 valley cover in the LS1howto.com website. The LS6 compared to the LS1 had little elevated circles all over it which looked like they might get into the way.
I'll try to find pics of each and post them later.
I don't think all blocks require the clearancing as much as it shows on ls1howto mine didn't seem to although it can be hard to compare to the pictures.
What do you think about that idea?
I guess I'll just go with the PCV upgrade only and leave the LS1 intake tube as is. I guess I could check to see if it'll fit when I swap the oil valley covers.
