LSx Motorhead Tidbit
Evidently the aluminum blocks grow enough when they heat up that the chain needs some slack in it. And the double rollers that are "nice & tight" can actually cause problems. One guy reported wearing out several front cam bearings, and even broke the front hub off of a cam.
Putting 2 & 2 together, I figure this also contributes to our random misfire issue. Thinking they have programmed this slop into the PCM, so we put tighter chains on there, and then install lighter weight converters or flywheels & rev the engines well past the 5600 they are set at, the cam position sensor signal is outside the window.
Anyway, it's something to consider if you build a motor. Sure makes an iron block look good!
I wasn't trying to make anyone paranoid, just passing info along. But maybe an LS2 chain is the answer. You'd think GM has figured out the solution by now.
Mike
