my cam card
Card reads as such 112 lsa, 13.1 valve overlap
Intake
centerline 108 atdc
valve open 9.5 btdc
close 45.1 abdc
duration 234.5
lobe lift .36937
valve lift .62793
lobe area 29.23
Exaust
centerline116
valve open 56.5 bbdc
closed 3.6 atdc
duration 240.1
lobe lift .37732
valve lift .64145
lobe area .30.09
Will be getting tuned next week from Tom hopefully. Started right up. Had no oil pressure so I shut it right down. The oil pump is working. I triple checked the pickup to pan clearance with clay and a ruler. I hit the OPSU a couple times removing the engine so I need to replace it. Checked it with a multi-meter and Wong and it checked out bad. Have a new one on the way and the intake is already off. All these little details that needed doing. Would have been a lot easier if I hadnt done the coil mod and painted my valve covers and polished a few things. Plus all the suspension stuff and new rear.
Thing purrred like a kitten though. I'm excited to get it on the road. I still need to bleed the clutch though. There is no pedal at all
I need to figure out how to bleed it by myself without a vac. You got to get before and after video of the car idleing and ****!
I'm interested in hearing that cam.
